OPPO control over IP
Hi control is working but I am get respond with timeout. why?
Command function:
function tcp_oppo(data, ip, port)  local sock = require('socket').tcp()  sock:settimeout(3)  local res, err = sock:connect(ip, port or 23)    if res then    res, err = sock:send('#' .. data .. '\r')    if res then      res, err = sock:receive('*a')    else      alert('send failed: ' .. tostring(err))      end  else    alert('connect failed: ' .. tostring(err))  end  sock:close()  return res, err end
Event:
ip = '192.168.11.105' if (event.getvalue() == true) then  res, err = tcp_oppo('POW', ip) end log (res, err)
Manual
Try adding a new line character when sending:
res, err = sock:send('#' .. data .. '\r\n')
(04.12.2018, 13:45)admin Wrote: Try adding a new line character when sending:
Nop it`s not hellp in logs I got the same:
Event for Test 2 (32/5/1) 04.12.2018 16:36:21 * arg: 1  * nil * arg: 2  * string: timeout
The remote host probably is not closing the socket after command that's why receive all (*a) is not working. You can get partial response like this:
function tcp_oppo(data, ip, port)   local sock = require('socket').tcp()   sock:settimeout(3)   local res, err = sock:connect(ip, port or 23)      if res then     res, err = sock:send('#' .. data .. '\r')     if res then       res, err, partial = sock:receive('*a')     else       alert('send failed: ' .. tostring(err))       end   else     alert('connect failed: ' .. tostring(err))   end   sock:close()   return res, err, partial end ---------------------------------- ip = '192.168.11.105' if (event.getvalue() == true) then   res, err, partial = tcp_oppo('POW', ip) end log (res, err, partial)
(04.12.2018, 14:45)admin Wrote: The remote host probably is not closing the socket after command that's why receive all (*a) is not working. You can get partial response like this:
Thanks admin its working I get 'partial'
How you think how to do to get status of device power when device will be turn on over remote that LM will know of Player status.
Upgrade LuaSocket package via System config > System > Packages:
https://dl.openrb.com/lm-18-imx6/pkg/lua...1_imx6.ipk
Then replace receive part with:
res, err, partial = sock:receive('*r')
(05.12.2018, 08:32)admin Wrote: Upgrade LuaSocket package via System config > System > Packages:
OK that working now I get sting in res.
How do that I get status of player in KNX objekt about power status. I mean that sometime can be that player will be turn on from original remote control I need to know.
You need to send QPW command then parse the result and update status object if needed. You will need a separate resident script for that. Make sure that you don't use one object for both control and status, otherwise you can get an infinite script loop.
