Threads: 94
13.02.2019, 16:04
(This post was last modified: 13.02.2019, 16:05 by gjniewenhuijse.)
Has anyone connected a Dyson Pure Hot+Cool 2018 ( 244289-01) or maybe another Dyson product that used the same protocol?
https://shop.dyson.nl/dyson-ventilatoren...-244289-01
Threads: 43
There are some Python libraries for control: https://github.com/CharlesBlonde/libpurecoollink
Internally MQTT is used which is supported by LM, but you need to get credentials before MQTT connection is possible.
Threads: 94
(15.02.2019, 08:34)admin Wrote: There are some Python libraries for control: https://github.com/CharlesBlonde/libpurecoollink
I already installed this device on my local network and have the right credentials for the Dyson app. How to start?
Threads: 43
Use standard MQTT example without encryption. Username is device serial number, password value are device credentials.
This resident script will connect to MQTT and subscribe to status topic. See logs tab for output result.
Code: -- product types
DYSON_PURE_COOL_LINK_TOUR = '475'
DYSON_PURE_COOL_LINK_DESK = '469'
DYSON_PURE_HOT_COOL_LINK_TOUR = '455'
DYSON_360_EYE = 'N223'
broker = '192.168.1.1' -- default port is 1883
username = '...' -- device serial
password = '...' -- device credentials
producttype = DYSON_PURE_HOT_COOL_LINK_TOUR
topic = producttype .. '/' .. username .. '/status'
mqtt = require('mosquitto')
client = mqtt.new()
client.ON_CONNECT = function(status, rc, err)
if status then
log('connect ok')
client:subscribe(topic)
log('connect error', rc, err)
client.ON_MESSAGE = function(mid, topic, data)
log('message', topic, data)
client:login_set(username, password)
client:connect(broker)
client:loop_forever()
Threads: 94
where to find the mosquitto module?
Resident script:19: module 'mosquitto' not found:
no field package.preload['mosquitto']
no file './mosquitto'
no file 'Library mosquitto'
no file 'Library mosquitto.so'
stack traceback:
[C]: in function 'require'
Threads: 43
Threads: 94
Threads: 43
Threads: 94
yes, packages are installed.
But how to find the password (device credentials) or is it possible to generate it?
Threads: 94
15.07.2019, 12:48
(This post was last modified: 15.07.2019, 13:05 by gjniewenhuijse.)
I think i need to get device information over HTTPS:
https://github.com/CharlesBlonde/libpure...k/dyson.py
Code: https = require 'ssl.https'
require('json')
socket.http.TIMEOUT = 5
local cUsername = 'xxxxxxxxx@xxxxxxxx.nl'
local cPassword = 'xxxxxxxxxxxxxx'
-- get session info
local cBody = '{"Email":"' .. cUsername .. '","Password":"' .. cPassword ..'"}'
local cReq = {}
local cUrl1 = 'https://api.cp.dyson.com/v1/userregistration/authenticate?country=NL'
result1 = https.request({
url = cUrl1,
method = 'POST',
headers = {
['content-length'] = #cBody,
['content-type'] = 'application/json'
source = ltn12.source.string(cBody),
sink = ltn12.sink.table(cReq)
if result1 and cReq then
log(cReq)
cAuth = cReq
log(result1)
result:
Code: * table:
[1]
* string: {"Account":"xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx","Password":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"}
How to get the account and password value in the following GET request to receive al devices from: /provisioningservice/manifest
Threads: 43
Send GET request to https://api.cp.dyson.com/v1/provisioning...e/manifest after the first one to get device list. You need to decode the first result using JSON and then pass Account ![Tongue Tongue](https://forum.logicmachine.net/images/smilies/tongue.png) assword values as Basic auth. See last example in HTTP docs: http://w3.impa.br/~diego/software/luasocket/http.html
Threads: 94
15.07.2019, 14:34
(This post was last modified: 15.07.2019, 14:34 by gjniewenhuijse.)
(15.07.2019, 13:27)admin Wrote: Send GET request to https://api.cp.dyson.com/v1/provisioning...e/manifest after the first one to get device list. You need to decode the first result using JSON and then pass Account assword values as Basic auth. See last example in HTTP docs: http://w3.impa.br/~diego/software/luasocket/http.html
i added Account and Password settings to the code below, but i only get a 403 error.
Code: mime = require("mime")
r, c = https.request {
url = 'https://api.cp.dyson.com/v1/provisioningservice/manifest',
method = 'GET',
headers = { authentication = "Basic " .. mime.b64("xxxxxxxxx:xxxxxxxxxxxx") }
log(r,c)
Threads: 43
Can you send your email/password via PM so I can test locally?
Threads: 94
(16.07.2019, 07:59)admin Wrote: Can you send your email/password via PM so I can test locally? done
Threads: 43
Thanks, turns out that example is incorrect. Correct header name should be authorization, not authentication. You also need to add sink table to the GET request so you can retrieve response data.
Threads: 94
(16.07.2019, 09:09)admin Wrote: Thanks, turns out that example is incorrect. Correct header name should be authorization, not authentication. You also need to add sink table to the GET request so you can retrieve response data.
Did you receive a response with a device in it?
local cReq2 = {}
local cUrl2 = 'https://api.cp.dyson.com/v1/provisioningservice/manifest'
result2, c, h = https.request({
url = cUrl2,
method = 'GET',
headers = {
['authorization'] = "Basic " .. mime.b64(cAccount..":"..cPassword)
sink = ltn12.sink.table(cReq2)
log(result2,c,h)
log(cReq2)
Now my response is a correct http request (code 200), but no data in cReq2
Threads: 43
When I tested with your account it returned empty device array []
Threads: 94
mmm something must be wrong, because i have one device in my account. I can control this device by the app with the same credentials.
Threads: 94
17.07.2019, 14:39
(This post was last modified: 17.07.2019, 14:39 by gjniewenhuijse.)
My model is HP04, inside is a code on a label, maybe i can use this because i read:
(After this initialization, you'll have to use the hashed password to connect to the fan. The hashed password is a base64 encoded of the sha512 of the password written on manual and on the fan label)
How to do this encryption in lua, in the Original python code i see:
Code: def decrypt_password(encrypted_password):
"""Decrypt password.
:param encrypted_password: Encrypted password
key = b'\x01\x02\x03\x04\x05\x06\x07\x08\t\n\x0b\x0c\r\x0e\x0f\x10' \
b'\x11\x12\x13\x14\x15\x16\x17\x18\x19\x1a\x1b\x1c\x1d\x1e\x1f '
init_vector = b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' \
b'\x00\x00\x00\x00'
cipher = AES.new(key, AES.MODE_CBC, init_vector)
json_password = json.loads(unpad(
cipher.decrypt(base64.b64decode(encrypted_password)).decode('utf-8')))
return json_password["apPasswordHash"]
Threads: 43
Try this for SHA512 + BASE64 encoding:
Code: require('encdec')
password = '123456'
password = encdec.sha512(password, true) -- binary form
password = encdec.base64enc(password)
Python code that you've posted does password decryption.
