15.03.2019, 12:23
Hello, is there a way to add units to bacnet objects (Celsius, ppm etc.)
BACnet unit type
15.03.2019, 12:23
17.03.2019, 19:09
For sure, yes.
Standard units here: https://www.google.com/url?sa=t&source=w...yxJPoKFr8Y Check out the AI object here: http://www.bacnet.org/Bibliography/ES-7-96/ES-7-96.htm Sent fra min SM-G960F via Tapatalk
17.03.2019, 19:32
(This post was last modified: 17.03.2019, 19:41 by Erwin van der Zwart.)
The fact that ASHRAE has specified something does not automatically means it is implemented. Manufacturers have a lot of freedom in BACnet even if a product is BTL listed. For a BACnet object there are only 3 properties mandatory and those are ID, Name and Type all other properties are optional including the property Unit. Nice thing to notice is that even the Value property is optional (: The Unit property is not existing in the BACnet objects that are hosted by the controller. BR, Erwin
17.03.2019, 19:46
Sorry, folx. I just joined in and did not realize that this was a product spefic forum. Hence my general remark about the BACnet units.
Obviously, I have never heard of the "Logic machine" controller before. So, I will just opt to leave this forum as there is not enough hours in a day for me to endulge in this hardware as well. Carry on! Sent fra min SM-G960F via Tapatalk
10.12.2019, 09:47
Is there any possibility to make more objects availible. Have an integrator complaining about the values exported from the Lm.
10.12.2019, 11:15
Which objects do you miss?
PS. BACnet units will be added in RC2
Ctrl+F5 |
