Button with delayed off
Hi.
Is it possible to implement button with delayed of? When input is triggered, then it sendts telegram on, and then telegram off after 1 second? Or maybe something adjustable in milliseconds?
Or maybe this has to be a choice on the output device instead? When a device recives an On telegram for an output, it switches the output On and then Off after the preset delay.
Kai-Roger
I can see that when i use LoRa, and want to make an impulse signal to something from an output device, the On and Off telegrams from the input device is too slow when LoRa parameters are set to long range. The best solution must be to have the possibility to set delayed Off on the output device to make a quick impulse. Then the longrange telegram from the input just have to be On telegram.
