How to prepare animation .svg file in the visualization on the Logic Machine?
Thanks,
Sławek Budzyński
Thanks,
Sławek Budzyński
SVG animation
How to prepare animation .svg file in the visualization on the Logic Machine? Thanks, Sławek Budzyński
23.07.2015, 13:33
What kind of animation do you want to add?
Please see the attached SVG file as an example. Keep in mind that it will not work as an object icon only as a separate image. (23.07.2015, 13:33)admin Wrote: What kind of animation do you want to add? Thank you for your answer ![]() I'd like to know how to add: 1) some motion icon e.g. spinning fan 1-stage or 3-stage fan, 2) some motion icon in menu. In what application do you prepare clock.svg graphics? I checked clock.svg on the visualisation demo and clock is working when I import it by "Image" object and clock is not working when I import it by "Link" or "Object".
24.07.2015, 09:37
Quote:I checked clock.svg on the visualisation demo and clock is working when I import it by "Image" object and clock is not working when I import it by "Link" or "Object".Yes, because SVG uses scripting and it's only available as a separate image but not as an icon. SVG can be created in Inkscape, Illustrator or any other vector editor that can export SVG. Animation might require adding some JavaScript manually. In your case maybe an animated GIF is the easiest solution?
24.07.2015, 11:53
(24.07.2015, 09:37)admin Wrote:Quote:I checked clock.svg on the visualisation demo and clock is working when I import it by "Image" object and clock is not working when I import it by "Link" or "Object".Yes, because SVG uses scripting and it's only available as a separate image but not as an icon. Yes, but isn't scalable ![]() In what application do you embedding js code?
29.07.2015, 06:04
(This post was last modified: 29.07.2015, 06:10 by Tinysprings.)
You could try may be to put a transparent svg icon linked to the group address on top of the animated svg ?
(29.07.2015, 06:30)admin Wrote: Working example attached There is some option. Thank you ![]() By the way, I learned a little about the structure of .svg files and editing it in Notepad ![]() <?xml version="1.0" encoding="utf-8"?> <!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd"> <svg version="1.1" id="Layer_1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" viewBox="0 0 56 56" enable-background="new 0 0 56 56" xml ![]() <circle fill="#6BB2DC" cx="28" cy="28" r="28"/> <g> <path fill="#FFFFFF" d="M31.853,27.044c1.209-0.434,3.227-0.71,5.165,0.366c3.293,1.829,6.39-0.953,5.938-4.036 c-0.399-2.73-2.086-5.511-4.228-6.628c-3.203-1.67-5.629-0.74-7.506,1.297c-1.229,1.335-2.515,3.689-2.614,5.929 c-0.048,1.054-1.271,0.998-1.565,0.177c-0.435-1.209-0.71-3.227,0.365-5.164c1.83-3.294-0.953-6.391-4.034-5.94 c-2.731,0.401-5.512,2.087-6.629,4.229c-1.67,3.203-0.74,5.628,1.297,7.505c1.335,1.229,3.69,2.516,5.929,2.615 c1.055,0.047,0.999,1.271,0.178,1.565c-1.21,0.435-3.229,0.71-5.165-0.366c-3.295-1.83-6.391,0.954-5.939,4.035 c0.399,2.731,2.086,5.511,4.229,6.629c3.203,1.669,5.629,0.74,7.505-1.297c1.229-1.335,2.516-3.69,2.614-5.929 c0.047-1.055,1.271-0.999,1.565-0.18c0.435,1.211,0.711,3.229-0.366,5.167c-1.829,3.293,0.954,6.39,4.036,5.938 c2.73-0.398,5.511-2.084,6.628-4.228c1.671-3.204,0.74-5.627-1.297-7.506c-1.334-1.228-3.69-2.515-5.928-2.613 C30.976,28.563,31.031,27.338,31.853,27.044z M28,29.522c-0.84,0-1.521-0.681-1.521-1.521c0-0.84,0.682-1.521,1.521-1.521 c0.841,0,1.521,0.682,1.521,1.521C29.521,28.842,28.841,29.522,28,29.522z"> <animateTransform attributeName="transform" type="rotate" from="0 28 28" to="360 28 28" dur="5s" repeatDur="indefinite"/> </path> </g> </svg> -SOME INFO ABOUT STRUCTURE- <g> grouping objects <path fill=....> this is the fan on out image <animateTransform attri....> this is the code which animating our fan (more info -> https://developer.mozilla.org/en-US/docs...eTransform). This code is between <path fill=....> and </path>
cool, I modify the clock to have a counter animation
It's ok but I need to put the GA in the SVG script. Is there a way to use for example the class specify in the design ? Should be great to put in the class field the GA and to take it in the script. J'ai essayé de voire ce que donnait this.parentNode.parentNode.className mais ca marche pas. Je fouille un peu le javascript.
FRANCE SMARTHOME & SMARTBUILDING INTEGRATION SE ECO EXPERT
13.07.2021, 05:31
(This post was last modified: 13.07.2021, 05:32 by benanderson_475.)
13.07.2021, 05:37
You can simply use two icons - one with animation and another without.
13.07.2021, 05:46
(This post was last modified: 13.07.2021, 05:48 by benanderson_475.)
09.03.2022, 13:05
