04.08.2019, 20:03
(03.05.2018, 06:40)Erwin van der Zwart Wrote: Hi,
You can use this script to map your modbus profiles to objects automatically.
PS: Make backup before you run it because there is a lot created (:
It creates 255 objects each run and skips already mapped objects, so you need to change to address scope and run it again for the next 255 objects. So for 1200 objects you need to run it 5 times.
Hi Erwin,
further to your reply above, this procedure is valid for modbus RTU as well?
I have about 20 modbus fancoils and I would like to generate knx objects for each modbus device.
The example is:
Knx addresses 1/1/xx for modbus address device 1.
Knx addresses 1/2/xx for modbus address device 2.
How can do that?
