08.10.2019, 10:56
Do I need a pullup resistor for 1-wire temperature sensors ds18b20 connected to Re:actor?
					1-wire pullup resistor
		08.10.2019, 10:56
		Hi, Do I need a pullup resistor for 1-wire temperature sensors ds18b20 connected to Re:actor?
		08.10.2019, 11:07
		Are you powering it from 5V or using parasitic power? From datasheet: VDD must be grounded for operation in parasite power mode.
		08.10.2019, 11:49
		08.10.2019, 12:05
		Pull-up is not needed but you can get more reliable readings by adding a capacitor (at least 0.1uF) between +5V and GND as close as possible to the sensor.
		10.10.2019, 12:02
