13.11.2019, 08:41
I have a SpaceLYnk running 2.3.0 where I'm not getting expected modbus error reporting. Initially I had 116 Modbus TCP/IP devices, but it seems the modbus library/stack hung as there are problems getting responses from the devices. I'm now setting everything up manually one by one so I can figure out which devices are causing problems. I've found the first one where I don't get the expected reply back, but there's no error in the Modbus log, nor is the device marked as red in the modbus panel. This is the first time I've experienced this. Anything I can do to test if modbus is working as expected on the SpaceLYnk?
