18.01.2020, 21:40
(This post was last modified: 18.01.2020, 21:42 by Erwin van der Zwart.)
We usually recommend ATP card type AF4GUDI-OEM
Your card is switched to read-only, this does not influence the performance, all operations are running in RAM, the changes you make are also running in RAM and you can do whatever you want to do, the downside is that every 30 minutes the changes made in RAM operation are stored to the SD card but you simply cannot write to the card to store your changes, this results in losing all made changes after a reboot, this is also why your upgrade is not performed.
