30.06.2020, 11:48
					Tooltip
		30.06.2020, 11:49
		You need to add this text there: tooltip tooltip-1
		01.07.2020, 06:52
		02.07.2020, 06:51
		02.07.2020, 07:18
		Custom name cannot be used but you can use object name like this. All elements that require a tooltip must have additional class set to tooltip Custom JavaScript: Code: $(function(){Custom CSS: Code: .usermode .tooltip:before {
		02.07.2020, 14:40
		hi I modified the css as suggested but when i try to insert the java code in a script i have an error in what type of script should i insert it?
		02.07.2020, 14:41
		Scripting - Tools - Edit Custom JavaScript
		11.01.2021, 16:07
		Hi, there is a way to use the tooltip with object name if the object in the user interface is 'read-only' ???
		12.01.2021, 07:32
		Replace this: Code: $(el).attr('data-name', obj.name);Code: $(el).attr('data-name', obj.name).removeClass('item-read-only');
		18.04.2023, 13:34
		Hello everyone, I know the thread is bit old but maybe someone can still help me. My problem: I added the custom javascript and custom css like this description said Now on the Logicmachine, where I tested the visu, everything works fine. But on the Spacelynk, in the productive environment, it doesn´t work. Also on the spacelynk there are no attributes in the HTML-Code like "data-object" or "data-name". If anybody can help me i´m very pleased.
		19.04.2023, 08:21
		This feature is not supported on older firmwares. Make sure you are running the latest version.
		19.04.2023, 17:56
		20.04.2023, 13:11
		You will have to wait for the next firmware update then.
		30.07.2023, 11:21
(This post was last modified: 30.07.2023, 11:48 by fleeceable.)
		Hi! I have a little problem with tooltip. Have quite many buttons and some tooltips gonna be behind other button. How it's possible to show tooltip top of any element? Tried to use z-index : 999 on .usermode .tooltip:hover:before section but no luck. CSS: Code: .usermode .tooltip:before {EDIT: Added additional code worked for me: Code: .usermode .tooltip:hover {
		30.07.2023, 14:04
	 (30.07.2023, 11:21)fleeceable Wrote: Hi!Do you mind sharing where you got your icons from?
		30.07.2023, 20:49
	 (30.07.2023, 14:04)Novodk Wrote:(30.07.2023, 11:21)fleeceable Wrote: Hi!Do you mind sharing where you got your icons from? I usually create icons by myself. I'm gonna add some to here. Feel free to use them. (Right click -> Open image in new tab -> Right click -> Save image as)
		31.07.2023, 08:45
	 (30.07.2023, 20:49)fleeceable Wrote:Thank you so much, they are very beautiful.(30.07.2023, 14:04)Novodk Wrote:(30.07.2023, 11:21)fleeceable Wrote: Hi!Do you mind sharing where you got your icons from? I have been looking for something like this for a project for ages   |
