Bacnet alarm class
Using the LM to export knx to bacnet objects.
One question about booleon signals. Is there some way to give a booleon value an notification class on bacnet side.
Bacnet is taken directly into BMS system, and they want the value to trigger with notification class.
This is not supported.
In your BMS you can attach an alarm object to the KNX exposed BACnet objects and in this alarm object you can create your notification class.
There is no option to make intrinsic alarms in the KNX exposed BACnet object itself.
