BLE TI SensorTag CC2650
I'm trying to get the Button Presses from the Sensor via the SensorTag BLE script provided in the LM.
I'm getting Data like Humidity etc, but no matter what i tried the button values don't update on button press.
return {   manufacturer = 'TI',   description = 'SensorTag',   default_name = 'SensorTag',   version = 2,   objects = {     {       id = 'temp',       name = 'Temperature',       datatype = dt.temperature     },     {       id = 'hum',       name = 'Humidity',       datatype = dt.scale     },     {       id = 'button1',       name = 'Button 1',       datatype = dt.switch     },     {       id = 'button2',       name = 'Button 2',       datatype = dt.switch     }   },   init = function(device)     local objects = device.objects     if not objects.button1 and not objects.button2 then       device.profile.step = nil     end     if not objects.temp and not objects.hum then       device.profile.read = nil     end   end,   setbutton = function(device, button, value)     local key = 'button' .. button     if device[ key ] ~= value then       device.writeobject(key, value)       device[ key ] = value     end   end,   step = function(device)     local sock, res, data, err, setbutton     sock = device.sock     setbutton = device.profile.setbutton     if not sock then       sock = ble.sock()       ble.settimeout(sock, 1)       -- try connecting       res = ble.connect(sock, device.mac)       if not res then         ble.close(sock)         device.setactive(false)         os.sleep(5)         return       end       -- enable button notification       ble.sockwritecmd(sock, 0x60, 1, 0)       device.sock = sock       setbutton(device, 1, false)       setbutton(device, 2, false)     end     res, data = ble.sockreadnotify(sock, 1)     -- read ok     if res then       data = data:byte(1)       setbutton(device, 1, bit.band(data, 1) == 1)       setbutton(device, 2, bit.band(data, 2) == 2)       device.setactive(true)     -- timeout or disconnect     else       res, err = ble.check(sock)       -- disconnect       if not res or err ~= 0 then         ble.close(sock)         device.sock = nil       end     end   end,   read = function(device)     local sock, res, status, values, rssi     if device.profile.step then       sock = device.sock       res = sock     else       sock = ble.sock()       ble.settimeout(sock, 1)       res = ble.connect(sock, device.mac)     end     -- connect ok, enable sensor, wait for conversion to finish, read the result     if res then       ble.sockwritecmd(sock, 0x3C, 1)       os.sleep(0.1)       res = ble.sockreadhnd(sock, 0x38)       -- read ok       if res then         status = true         values = {}         rssi = ble.getrssi(device.mac)         -- convert temperature         tmp = bit.bor(bit.lshift(res:byte(2), 8), res:byte(1))         tmp = -46.85 + 175.72 / 65536 * tmp;         values.temp = math.floor(tmp * 10) / 10         -- convert humidity         tmp = bit.bor(bit.lshift(res:byte(4), 8), res:byte(3))         tmp = -6.0 + 125.0 / 65536 * bit.band(tmp, 0xFFFC)         values.hum = math.floor(tmp + 0.5)       end       -- disable sensor       ble.sockwritecmd(sock, 0x3C, 0)     end     if not device.profile.step then       ble.close(sock)     end     return status, values, rssi   end }
Might be bug somewhere, BLE has not been updated for some time. What is your use case for BLE? We are going to have ZigBee support in LM soon if you need wireless buttons/sensors.
(15.09.2020, 09:34)admin Wrote: Might be bug somewhere, BLE has not been updated for some time. What is your use case for BLE? We are going to have ZigBee support in LM soon if you need wireless buttons/sensors.
The main use case for BLE would be to detect via magnetic key (which this sensor is capable of) if the door to a server room is open or closed.
Is there an ETA on ZigBee support?
ZigBee is still in development. If you want to test then we can provide a USB dongle for LM. ZigBee door/window sensors are not supported yet but will be added soon.
