29.09.2020, 10:36
For the last FW, in the attached video I have binary object (set for main and status object) which status is set to not respond to main object's commands. If status is changed manually, graphic shows correct state. However, if graphic element is used in visu environment then in order for the graphic status to update correctly it is necessary to "align" first to the main's object state.
Is it a bug or is the way touch visu is set? I there any way around this issue?
https://1drv.ms/v/s!ApPVtjvdHVa6hIMcetZz...?e=ck4vqv+
Thanks in advance!
Thanks in advance!
