17.12.2020, 09:25
Hi, I want to know the steps on how to parameter my hL or sL to get internet and access the Marketplace to download apps.
thanks!
thanks!
connect to internet and access Marketplace
17.12.2020, 09:25
thanks!
17.12.2020, 09:33
Go to System->Network->Interface. Set everything apart of IP same as your PC network settings. In IP you should have the last number different from the on in your PC. You must make sure no other device use the same on your network.
17.12.2020, 10:02
hi thanks for quick reply! you mean this window right ?
17.12.2020, 10:03
Yes and you need Gateway IP, for DNS you can always go for 8.8.8.8
17.12.2020, 10:15
I tried everything, I still have no internet access.
I copied the internet settings on my computer, does being connected to WiFi affect this ?
17.12.2020, 10:26
Drop a screenshot what you have on PC and what you did in HL, there is nothing secret here.
17.12.2020, 10:26
Don't forget to reboot your device after changing network settings.
17.12.2020, 10:40
This looks OK, Did you press this RED button to apply changes? If not go to System->System->Reboot.
You can add secondary DNS 8.8.4.4
17.12.2020, 10:47
yeah of course, after every changes I reboot it
i also added secondary DNS but still not working.. however after giving these settings, it starts loading for few secondes after I click on the Marketplace, then it shows me the same message : "Cannot load application list. Check that ......"
17.12.2020, 10:53
Go to System->Status->Network Utilities and ping logicmachine.net
17.12.2020, 10:57
17.12.2020, 11:02
Try changing DNS to 192.168.0.1
Ping also 192.168.0.1
17.12.2020, 11:06
17.12.2020, 11:25
Can you do the ping from PC to the same ?
17.12.2020, 11:34
17.12.2020, 11:42
17.12.2020, 11:44
Status - System logs drop what you have there.
17.12.2020, 11:58
(17.12.2020, 11:44)Daniel. Wrote: Status - System logs drop what you have there.Dec 17 11:56:13 Wiser for KNX daemon.notice openvpn[1056]: SIGUSR1[soft,init_instance] received, process restarting Dec 17 11:56:13 Wiser for KNX daemon.warn openvpn[1056]: Could not determine IPv4/IPv6 protocol Dec 17 11:56:13 Wiser for KNX daemon.err openvpn[1056]: RESOLVE: Cannot resolve host address: hlynk-vpn.wiserair.com:80 (Try again) Dec 17 11:56:08 Wiser for KNX daemon.err openvpn[1056]: RESOLVE: Cannot resolve host address: hlynk-vpn.wiserair.com:80 (Try again) Dec 17 11:56:03 Wiser for KNX daemon.info avahi-daemon[1040]: Service "Web Server on WiserforKNX" (/etc/avahi/services/http.service) successfully established. Dec 17 11:56:03 Wiser for KNX daemon.info avahi-daemon[1040]: Server startup complete. Host name is WiserforKNX.local. Local service cookie is 1543352448. Dec 17 11:56:02 Wiser for KNX daemon.notice openvpn[1054]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.10 Dec 17 11:56:02 Wiser for KNX daemon.notice openvpn[1054]: OpenVPN 2.4.9 arm-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] Dec 17 11:56:02 Wiser for KNX user.info sysinit: starting openvpn Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Registering HINFO record with values 'ARMV5TEJL'/'LINUX'. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Registering new address record for 192.168.0.98 on eth0.IPv4. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Network interface enumeration completed. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: New relevant interface eth0.IPv4 for mDNS. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.98. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Loading service file /etc/avahi/services/http.service. Dec 17 11:56:02 Wiser for KNX daemon.warn avahi-daemon[1040]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns! Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: avahi-daemon 0.7 starting up. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Successfully dropped root privileges. Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534). Dec 17 11:55:56 Wiser for KNX user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK Dec 17 11:55:52 Wiser for KNX kern.notice kernel: [ 18.867299] random: nonblocking pool is initialized Dec 17 11:55:40 Wiser for KNX kern.info kernel: [ 6.387062] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Dec 17 11:55:38 Wiser for KNX authpriv.info dropbear[800]: Running in background Dec 17 11:55:38 Wiser for KNX authpriv.warn dropbear[795]: Failed loading /etc/dropbear/dropbear_ed25519_host_key Dec 17 11:55:38 Wiser for KNX kern.info kernel: [ 4.715322] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc Dec 17 11:55:38 Wiser for KNX user.info sysinit: /dev/mmcblk0p3: clean, 3409/228032 files, 84966/911104 blocks Dec 17 11:55:38 Wiser for KNX user.info sysinit: e2fsck 1.45.6 (20-Mar-2020) Dec 17 11:55:38 Wiser for KNX kern.info kernel: [ 4.386899] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1) Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 3.122301] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1) Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 2.843504] watchdog timeout 60 seconds Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 1.752845] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.942147] Freeing unused kernel memory: 144K Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.941334] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.941028] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.775913] mmcblk0: p1 p2 p3 Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.773252] mmcblk0: mmc0:59b4 USD 3.73 GiB Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.771039] mmc0: new high speed SDHC card at address 59b4 Dec 17 11:55:36 Wiser for KNX kern.warn kernel: [ 0.768914] mmc0: host does not support reading read-only switch, assuming write-enable Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.763236] Waiting for root device /dev/mmcblk0p2... Dec 17 11:55:36 Wiser for KNX kern.err kernel: [ 0.762943] Warning: unable to open an initial console. Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.761000] rtc-ds1307 0-006f: setting system clock to 2020-12-17 11:55:34 UTC (1608206134) Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.754792] NET: Registered protocol family 17 Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.754611] ip_tables: © 2000-2006 Netfilter Core Team Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.731263] mxs-mmc 80010000.ssp: initialized Dec 17 11:55:36 Wiser for KNX kern.warn kernel: [ 0.699805] 80010000.ssp supply vmmc not found, using dummy regulator Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.698662] usbcore: registered new interface driver btusb Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.693141] lirc_dev: IR Remote Control driver registered, major 248 Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.691725] i2c /dev entries driver Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.690170] rtc-ds1307 0-006f: 64 bytes nvram Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.690045] rtc-ds1307 0-006f: rtc core: registered mcp7941x as rtc0 |
