10.10.2016, 14:35
Any of you has idea how to dimm a German Burda infrared heater?
Looks that they have a bluetooth dimmer (which cost 300EUR!), but I was wondering if I can do it cheaper with a DIN-rail device that can handle a load of maximum 2kW. If no such DIN-rail device exists, do you know any outdoor dimmer for heaters, that I can connect it to the KNX bus?
I am looking for a KNX solution, because I don't want to use dedicated iPhone applications for each little thing. Instead, I want to have an all-in-one solution. Note that on the balcony where the heater is installed, I already have a temperature and presence sensor, IP24, from Schneider Electric.
Possible scenes that can include these two sensors? Ideas?
Thank you,
Andreas
Thank you,
Andreas
