USB/ekey bug?
I'm using eKey FSX app connected to an ekey using a USB-RS485 adapter, which uses /dev/ttypUSB0 as it's the only 'usb device' connected to Wiser.  Most of the time everything works fine, but sometimes I noticed my ekey gets disconnected - and when I check the logs I see a storm of:
Quote:Aug 26 10:03:30 wiser kern.err kernel: [78950.816576] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:29 wiser kern.err kernel: [78949.817573] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:28 wiser kern.err kernel: [78948.815564] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:27 wiser kern.err kernel: [78947.808566] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:26 wiser kern.err kernel: [78946.809623] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:25 wiser kern.err kernel: [78945.809576] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:24 wiser kern.err kernel: [78944.809573] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:23 wiser kern.err kernel: [78943.808560] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:22 wiser kern.err kernel: [78942.809568] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
Aug 26 10:03:21 wiser kern.err kernel: [78941.809606] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
repeats once a second while USB adapter is connected
If I re-plug the USB adapter to wiser, it detects the adapter and assigns it to /dev/ttyUSB1:
Quote:Aug 26 10:03:40 wiser kern.info kernel: [78961.098810] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB1
Aug 26 10:03:40 wiser kern.info kernel: [78961.097070] usb 1-1: Detected FT232RL
Aug 26 10:03:40 wiser kern.info kernel: [78961.096879] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
Aug 26 10:03:40 wiser kern.info kernel: [78961.091624] usb 1-1: SerialNumber: A10KNCJH
Aug 26 10:03:40 wiser kern.info kernel: [78961.091613] usb 1-1: Manufacturer: FTDI
Aug 26 10:03:40 wiser kern.info kernel: [78961.091601] usb 1-1: Product: FT232R USB UART
Aug 26 10:03:40 wiser kern.info kernel: [78961.091589] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 26 10:03:40 wiser kern.info kernel: [78961.091561] usb 1-1: New USB device found, idVendor=0403, idProduct=6001
Aug 26 10:03:40 wiser kern.info kernel: [78960.945855] usb 1-1: new full-speed USB device number 3 using ci_hdrc
Aug 26 10:03:30 wiser kern.info kernel: [78951.178812] ftdi_sio 1-1:1.0: device disconnected
Aug 26 10:03:30 wiser kern.info kernel: [78951.178743] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
Aug 26 10:03:30 wiser kern.info kernel: [78951.176855] usb 1-1: USB disconnect, device number 2
eKey still won't work in this case because it's expecting the fingerprint reader to be on /dev/ttyUSB0.
The only 'solution' is to reboot Wiser which then comes back up with everything working - USB adapter assigned to /dev/ttyUSB0 and consequently ekey detecting the fingerprint reader - everything is okay until the next time the above kernel messages appear.
I have tried 2 different USB-RS485 adapters and the problem occurs in both.
Is this a bug in the kernel / USB driver? how do I get this resolved?
Thank you!
Morkov
This is a hardware not a software issue. What is the USB cable length or does this adapter plug directly into the USB port? There are many counterfeit FTDI adapters which might be unreliable.
Okay, thank you for the response.  The length is very small and it does plug directly into USB, but I cannot be 100% sure the adapter is not to blame.
Thank you!
Morkov
Try to change diferent USB adapter location in the tab "Scanners" data block 'Configuration' by entering:
http://__your_lm_ip_address_/apps/data/ekey/admin.lp
Than start the ekey App daemon again.
