26.10.2021, 09:42
I have some questions about this system:
1) is it possible to add Bluetooth? If yes, is it possible to stream bluetooth audio between different players?
2) Is it possible to add IR communication as in the "with amplifier" version?
3) Loudspeaker outputs: the manual says 4-8 Ohms, how many Watt max?
4) Since it is the same "family" of products, I assume that I can integrate the amatilinea webvisu in an iframe and leave it as it is in the Logicmachine or Wiser for KNX visualization, right? Is there a way even to slightly modify the graphical aspects (e.g. colors with css)?
5) I suppose that it's not designed to integrate analog devices, there is no way to add at least one analog input, right?
Thank you for your help.
Note that only older Apple remote is supported at the moment.
