Zigbee gateway integration
#81
(05.11.2021, 07:22)admin Wrote: @gtsamis, it is more complicated because this device does not use standard ZigBee clusters. Instead it only uses ZigBee as a transport for TRV control and status messages. Some more info on this: https://medium.com/@dzegarra/zigbee2mqtt...92707e882d
Cool They are too cheep to be true!
So any suggestions for certified TRV that can work with LM?
Is it possible to add a profile for Develco SPLZB-131 on/off schuko plug with powermetering?
It's adding but is not responding to any commands, or reporting back, seems like it's repeating signal as it is range expanding to my lights bulbs.
Log is empty for operation on the device on off button. Aattatched log output controlling device from zigbee app (all buttons tested) Read status goes timeout.
Here is screenprint of device.
.txt   zigbee-monitor.txt (Size: 708 bytes / Downloads: 16)
Can i use this with a LM Ambient?
Depends on the CPU model. At this moment only i.MX6 is supported.
(23.11.2021, 08:33)admin Wrote: Depends on the CPU model. At this moment only i.MX6 is supported.
LMWNCO2-ZR
Go to the LM app store. If ZigBee app is there then it can be installed on your device.
Hello
I have an installation which cannot be connected to the internet and I would like to put the ZigBee module.
Can we have the zigbee installation file?
thx
https://dl.openrb.com/pkg/zigbee-20211116.ipk
(09.12.2021, 12:01)admin Wrote: https://dl.openrb.com/pkg/zigbee-20211116.ipk
Could you please resend the link for the download?
I have a USB CC2531 but in the application the status icon appears red.
In the syslog if the USB Dongle is recognized, is there anything else that needs to be configured?
Here's the current version: https://dl.openrb.com/pkg/zigbee-20211217.ipk
(02.01.2022, 13:03)admin Wrote: Here's the current version: https://dl.openrb.com/pkg/zigbee-20211217.ipk
Hello
it is possible to publish profiles without bytecode?
For community integration 3party devices.
Custom profiles will be implemented later on. Which device do you want to integrate?
thanks for the file
Is any additional configuration necessary?
Status icon is still red
Did you get the dongle from us or have you bought it yourself? The dongle must be flashed with correct firmware before it can be used. This has to be done via an external programming device.
(03.01.2022, 06:32)admin Wrote: Did you get the dongle from us or have you bought it yourself? The dongle must be flashed with correct firmware before it can be used. This has to be done via an external programming device.
I bought it myself. Is it possible to make this update?
You will need additional hardware for this. See this guide: https://www.zigbee2mqtt.io/guide/adapter...c2531.html
(11.08.2021, 07:50)Daniel Wrote: We have first prototypes and they do work great. To official sale it is still  a while 2-3 months I think.
Hi Daniel,
First of all Best wishes to you and the embedded Systems Team!
Any update on the offical sale of the zigbee devices with remote antenna?
Greetings,
tig
We are in process of making 4rth version, I hope last one.
Hello, I have Silvercrest Smart Plug from Lidl and feedback object dont work. Whats wrong?
2022-01-07 22:31:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
{ SrcAddr = 0, Status = 0 }
2022-01-07 22:31:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:31:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:31:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:31:47    ZNP: sending request:
[9] FE 04 25 36 FF FF 00 00 17
2022-01-07 22:31:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
{ AddrMode = 255, TCSignificance = 0, Duration = 0, DstAddr = 65535 }
2022-01-07 22:31:47    ZB: permit join: -1
2022-01-07 22:30:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:30:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:30:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:30:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:30:47    ZNP: sending request:
2022-01-07 22:30:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:30:47    ZB: permit join: -1
2022-01-07 22:29:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:29:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:29:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:29:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:29:47    ZNP: sending request:
2022-01-07 22:29:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:29:47    ZB: permit join: -1
2022-01-07 22:29:45    CC: MT command SRSP_ZDO_EXT_ROUTE_DISC, payload:
{ Status = 0 }
2022-01-07 22:29:45    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x45, data:
[3] 65 45 00
2022-01-07 22:29:45    ZNP: sending request:
[9] FE 04 25 45 FC FF 03 03 67
2022-01-07 22:29:45    SREQ: sending ZDO_EXT_ROUTE_DISC, data:
{ Radius = 3, DestinationAddress = 65532, Options = 3 }
2022-01-07 22:29:45    ZB: send many to one route request
2022-01-07 22:28:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:28:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:28:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:28:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:28:47    ZNP: sending request:
2022-01-07 22:28:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:28:47    ZB: permit join: -1
2022-01-07 22:27:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:27:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:27:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:27:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:27:47    ZNP: sending request:
2022-01-07 22:27:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:27:47    ZB: permit join: -1
2022-01-07 22:27:15    CC: MT command SRSP_ZDO_EXT_ROUTE_DISC, payload:
{ Status = 0 }
2022-01-07 22:27:15    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x45, data:
[3] 65 45 00
2022-01-07 22:27:15    ZNP: sending request:
2022-01-07 22:27:15    SREQ: sending ZDO_EXT_ROUTE_DISC, data:
2022-01-07 22:27:15    ZB: send many to one route request
2022-01-07 22:26:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:26:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:26:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:26:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:26:47    ZNP: sending request:
2022-01-07 22:26:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:26:47    ZB: permit join: -1
2022-01-07 22:26:13    ZCL OK 0c4314fffe6ff041
4
2022-01-07 22:26:13    CC: MT command AREQ_AF_DATA_CONFIRM, payload:
{ Status = 0, TransId = 4, Endpoint = 1 }
2022-01-07 22:26:13    CC: MT type AREQ (2), subsystem AF (0x04), command id 0x80, data:
[5] 44 80 00 01 04
2022-01-07 22:26:13    CC: MT command SRSP_AF_DATA_REQUEST, payload:
{ Status = 0 }
2022-01-07 22:26:13    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x01, data:
[3] 64 01 00
2022-01-07 22:26:13    ZNP: sending request:
[18] FE 0D 24 01 16 E3 0B 01 06 00 04 00 1E 03 11 04 00 DD
2022-01-07 22:26:13    SREQ: sending AF_DATA_REQUEST, data:
{ ClusterId = 6, DstEndpoint = 11, Data = [ 17, 4, 0 ], DstAddr = 58134, Radius = 30, Options = [  ], TransId = 4, SrcEndpoint = 1 }
2022-01-07 22:26:13    ZB: sending ZCL message to 0c4314fffe6ff041, cluster 0006:
{ FrameControl = [ "FrameTypeLocal", "DirectionToServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 4, OnOffClusterFrame = { CommandIdentifier = "Off" } }
2022-01-07 22:26:11    ZCL OK 0c4314fffe6ff041
3
2022-01-07 22:26:11    CC: MT command AREQ_AF_DATA_CONFIRM, payload:
{ Status = 0, TransId = 3, Endpoint = 1 }
2022-01-07 22:26:11    CC: MT type AREQ (2), subsystem AF (0x04), command id 0x80, data:
[5] 44 80 00 01 03
2022-01-07 22:26:11    CC: MT command SRSP_AF_DATA_REQUEST, payload:
{ Status = 0 }
2022-01-07 22:26:11    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x01, data:
[3] 64 01 00
2022-01-07 22:26:11    ZNP: sending request:
[18] FE 0D 24 01 16 E3 0B 01 06 00 03 00 1E 03 11 03 01 DC
2022-01-07 22:26:11    SREQ: sending AF_DATA_REQUEST, data:
{ ClusterId = 6, DstEndpoint = 11, Data = [ 17, 3, 1 ], DstAddr = 58134, Radius = 30, Options = [  ], TransId = 3, SrcEndpoint = 1 }
2022-01-07 22:26:11    ZB: sending ZCL message to 0c4314fffe6ff041, cluster 0006:
{ FrameControl = [ "FrameTypeLocal", "DirectionToServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 3, OnOffClusterFrame = { CommandIdentifier = "On" } }
2022-01-07 22:26:08    ZCL OK 0c4314fffe6ff041
2022-01-07 22:26:08    CC: MT command AREQ_AF_DATA_CONFIRM, payload:
{ Status = 0, TransId = 2, Endpoint = 1 }
2022-01-07 22:26:08    CC: MT type AREQ (2), subsystem AF (0x04), command id 0x80, data:
[5] 44 80 00 01 02
2022-01-07 22:26:08    CC: MT command SRSP_AF_DATA_REQUEST, payload:
{ Status = 0 }
2022-01-07 22:26:08    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x01, data:
[3] 64 01 00
2022-01-07 22:26:08    ZNP: sending request:
[18] FE 0D 24 01 16 E3 0B 01 06 00 02 00 1E 03 11 02 00 DD
2022-01-07 22:26:08    SREQ: sending AF_DATA_REQUEST, data:
{ ClusterId = 6, DstEndpoint = 11, Data = [ 17, 2, 0 ], DstAddr = 58134, Radius = 30, Options = [  ], TransId = 2, SrcEndpoint = 1 }
2022-01-07 22:26:08    ZB: sending ZCL message to 0c4314fffe6ff041, cluster 0006:
{ FrameControl = [ "FrameTypeLocal", "DirectionToServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 2, OnOffClusterFrame = { CommandIdentifier = "Off" } }
2022-01-07 22:26:06    ZCL OK 0c4314fffe6ff041
2022-01-07 22:26:06    CC: MT command AREQ_AF_DATA_CONFIRM, payload:
{ Status = 0, TransId = 1, Endpoint = 1 }
2022-01-07 22:26:06    CC: MT type AREQ (2), subsystem AF (0x04), command id 0x80, data:
[5] 44 80 00 01 01
2022-01-07 22:26:06    CC: MT command SRSP_AF_DATA_REQUEST, payload:
{ Status = 0 }
2022-01-07 22:26:06    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x01, data:
[3] 64 01 00
2022-01-07 22:26:06    ZNP: sending request:
[18] FE 0D 24 01 16 E3 0B 01 06 00 01 00 1E 03 11 01 01 DC
2022-01-07 22:26:06    SREQ: sending AF_DATA_REQUEST, data:
{ ClusterId = 6, DstEndpoint = 11, Data = [ 17, 1, 1 ], DstAddr = 58134, Radius = 30, Options = [  ], TransId = 1, SrcEndpoint = 1 }
2022-01-07 22:26:06    ZB: sending ZCL message to 0c4314fffe6ff041, cluster 0006:
{ FrameControl = [ "FrameTypeLocal", "DirectionToServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 1, OnOffClusterFrame = { CommandIdentifier = "On" } }
2022-01-07 22:25:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:25:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:25:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:25:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:25:47    ZNP: sending request:
2022-01-07 22:25:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:25:47    ZB: permit join: -1
2022-01-07 22:24:47    CC: MT command AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, payload:
2022-01-07 22:24:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xB6, data:
[5] 45 B6 00 00 00
2022-01-07 22:24:47    CC: MT command AREQ_ZDO_PERMIT_JOIN_IND, payload:
{ PermitJoinDuration = 0 }
2022-01-07 22:24:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xCB, data:
[3] 45 CB 00
2022-01-07 22:24:47    CC: MT command SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, payload:
{ Status = 0 }
2022-01-07 22:24:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x36, data:
[3] 65 36 00
2022-01-07 22:24:47    ZNP: sending request:
2022-01-07 22:24:47    SREQ: sending ZDO_MGMT_PERMIT_JOIN_REQ, data:
2022-01-07 22:24:47    CC: initialized
2022-01-07 22:24:47    CC: MT command SRSP_AF_INTER_PAN_CTL, payload:
{ Status = 0 }
2022-01-07 22:24:47    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x10, data:
[3] 64 10 00
[7] FE 02 24 10 02 02 36
2022-01-07 22:24:47    SREQ: sending AF_INTER_PAN_CTL_InterPanReg, data:
{ Endpoint = 2 }
2022-01-07 22:24:47    CC: MT command SRSP_AF_REGISTER, payload:
{ Status = 0 }
2022-01-07 22:24:47    CC: MT type SRSP (3), subsystem AF (0x04), command id 0x00, data:
[3] 64 00 00
[18] FE 0D 24 00 02 5E C0 40 08 00 00 01 00 10 01 00 10 FD
2022-01-07 22:24:47    SREQ: sending AF_REGISTER, data:
{ AppInClusterList = [ 4096 ], AddDevVer = 0, AppDeviceId = 2112, AppOutClusterList = [ 4096 ], AppProfId = 49246, EndPoint = 2, LatencyReq = [ "NoLatency" ] }
{ Status = 0 }
[3] 64 00 00
[18] FE 0D 24 00 01 04 01 05 00 00 00 01 06 00 01 06 00 28
{ AppInClusterList = [ 6 ], AddDevVer = 0, AppDeviceId = 5, AppOutClusterList = [ 6 ], AppProfId = 260, EndPoint = 1, LatencyReq = [ "NoLatency" ] }
2022-01-07 22:24:47    CC: MT command SRSP_ZDO_END_DEVICE_ANNCE, payload:
{ Status = 0 }
2022-01-07 22:24:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x0A, data:
[3] 65 0A 00
2022-01-07 22:24:47    CC: device state changed to 9
2022-01-07 22:24:47    CC: MT command AREQ_ZDO_STATE_CHANGE_IND, payload:
{ State = 9 }
2022-01-07 22:24:47    CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xC0, data:
[3] 45 C0 09
[16] FE 0B 25 0A 00 00 34 12 CE 1C 00 4B 12 00 8E 07
2022-01-07 22:24:47    SREQ: sending ZDO_END_DEVICE_ANNCE, data:
{ Capabilities = [ "ZigbeeRouter", "MainPowered", "ReceiverOnWhenIdle", "AllocateShortAddress" ], NwkAddr = 0, IEEEAddr = "00124b001cce1234" }
2022-01-07 22:24:47    CC: MT command SRSP_ZDO_STARTUP_FROM_APP, payload:
{ Status = 0 }
2022-01-07 22:24:47    CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x40, data:
[3] 65 40 00
2022-01-07 22:24:46    ZNP: sending request:
[7] FE 02 25 40 00 00 67
2022-01-07 22:24:46    SREQ: sending ZDO_STARTUP_FROM_APP, data: nil
2022-01-07 22:24:46    CC: subscribed to MT_DEBUG events
2022-01-07 22:24:46    CC: MT command SRSP_UTIL_CALLBACK_SUB_CMD, payload:
{ Status = 0 }
2022-01-07 22:24:46    CC: MT type SRSP (3), subsystem UTIL (0x07), command id 0x06, data:
[3] 67 06 00
[8] FE 03 27 06 00 08 01 2B
2022-01-07 22:24:46    SREQ: sending UTIL_CALLBACK_SUB_CMD, data:
{ Action = [ "Enable" ], Subsystem = [ "MT_DEBUG" ] }
2022-01-07 22:24:46    CC: subscribed to MT_SYS events
{ Status = 0 }
[3] 67 06 00
[8] FE 03 27 06 00 01 01 22
{ Action = [ "Enable" ], Subsystem = [ "MT_SYS" ] }
2022-01-07 22:24:46    CC: subscribed to MT_ZDO events
{ Status = 0 }
[3] 67 06 00
[8] FE 03 27 06 00 05 01 26
{ Action = [ "Enable" ], Subsystem = [ "MT_ZDO" ] }
2022-01-07 22:24:46    CC: subscribed to MT_UTIL events
{ Status = 0 }
[3] 67 06 00
[8] FE 03 27 06 00 07 01 24
{ Action = [ "Enable" ], Subsystem = [ "MT_UTIL" ] }
2022-01-07 22:24:46    CC: subscribed to MT_AF events
{ Status = 0 }
[3] 67 06 00
[8] FE 03 27 06 00 04 01 27
{ Action = [ "Enable" ], Subsystem = [ "MT_AF" ] }
2022-01-07 22:24:46    CC: MT command SRSP_ZB_READ_CONFIGURATION, payload:
{ Status = 0, ConfigId = 98, Value = [ 255, 106, 134, 224, 50, 48, 128, 101, 227, 6, 124, 152, 131, 228, 55, 130 ] }
2022-01-07 22:24:46    CC: MT type SRSP (3), subsystem SAPI (0x06), command id 0x04, data:
[21] 66 04 00 62 10 FF 6A 86 E0 32 30 80 65 E3 06 7C 98 83 E4 37 82
[6] FE 01 26 04 62 41
2022-01-07 22:24:46    SREQ: sending ZB_READ_CONFIGURATION, data:
{ ConfigId = 98 }
2022-01-07 22:24:46    CC: MT command SRSP_SYS_OSAL_NV_READ, payload:
{ Status = 0, Value = [ 89, 5, 2, 16, 20, 16, 0, 30, 0, 0, 0, 1, 5, 1, 143, 7, 0, 2, 5, 30, 0, 0, 16, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 189, 76, 8, 0, 0, 1, 0, 15, 15, 5, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 52, 18, 206, 28, 0, 75, 18, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 15, 3, 1, 0, 0, 10, 1, 0, 0, 2, 0, 0 ] }
2022-01-07 22:24:46    CC: MT type SRSP (3), subsystem SYS (0x01), command id 0x08, data:
[114] 61 08 00 6E 59 05 02 10 14 10 00 1E 00 00 00 01 05 01 8F 07 00 02 05 1E 00 00 10 00 00 00 00 00 00 00 00 00 00 BD 4C 08 00 00 01 00 0F 0F 05 00 01 00 00 00 01 00 00 00 00 34 12 CE 1C 00 4B 12 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 03 01 00 00 0A 01 00 00 02 00 00
[8] FE 03 21 08 21 00 00 0B
2022-01-07 22:24:46    SREQ: sending SYS_OSAL_NV_READ, data:
{ ConfigId = 33 }
2022-01-07 22:24:46    CC: MT command SRSP_SYS_GET_EXTADDR, payload:
{ ExtAddress = "00124b001cce1234" }
2022-01-07 22:24:46    CC: MT type SRSP (3), subsystem SYS (0x01), command id 0x04, data:
[10] 61 04 34 12 CE 1C 00 4B 12 00
[5] FE 00 21 04 25
2022-01-07 22:24:46    SREQ: sending SYS_GET_EXTADDR, data: nil
2022-01-07 22:24:46    CC: firmware supports all needed features
2022-01-07 22:24:46    CC: MT command SRSP_SYS_PING, payload:
{ Capabilities = [ "MT_CAP_SYS", "MT_CAP_AF", "MT_CAP_ZDO", "MT_CAP_SAPI", "MT_CAP_UTIL", "MT_CAP_APP" ] }
2022-01-07 22:24:46    CC: MT type SRSP (3), subsystem SYS (0x01), command id 0x01, data:
[4] 61 01 79 01
[5] FE 00 21 01 20
2022-01-07 22:24:46    SREQ: sending SYS_PING, data: nil
2022-01-07 22:24:46    CC: reset successful (0)
2022-01-07 22:24:46    CC: MT command AREQ_SYS_RESET_IND, payload:
{ Reason = "PowerUp", TransportRev = 2, MinorRel = 6, MajorRel = 2, HwRev = 3, Product = 0 }
2022-01-07 22:24:46    CC: MT type AREQ (2), subsystem SYS (0x01), command id 0x80, data:
[8] 41 80 00 02 00 02 06 03
2022-01-07 22:24:45    ZNP: sending request:
[6] FE 01 41 00 01 41
2022-01-07 22:24:45    AREQ: sending SYS_RESET_REQ, data:
{ Type = 1 }
2022-01-07 22:24:45    CC: resetting device
@merel, support for this device will be added in the next version which should be published this week.
Edit: updated app has been published in the store.
