07.11.2016, 11:13
I have an Ekey finger scanner (Ekey module 861667553) connected to my LM4 (firmware version 20160714).
The Ekey system was installed using the procedure described the in http://openrb.com/ekey-biometric-scanner-interconnection-with-lm
The script used to detect a finger is exactly the same as described in the procedure:
The fingerscan works but there is always an error message in the Error Log:
Line 3: bad argument #1 to 'rshift' (number expected, got boolean)
Should I worry about this?
value = event.getvalue('14/2/0')
user = bit.rshift(value, 4)
finger = bit.band(value, 0x0F)
