Threads: 1
07.11.2016, 14:43
after an installation of a Homelynk at a customer, i need to reprogram some KNX equipements for a very little thing.
is it possible to create a VPN connection to a Homelynk to be able to program from a distance with ETS ?
Best regards, David Dumont
Threads: 2
08.11.2016, 12:18
(This post was last modified: 08.11.2016, 12:20 by cumulusnimbus.)
Sure. Just do a port forward of port 3671 from the internet facing router and to port 3671 on the Homelynk/LogicMachine device. This is usually done under NAT / Port Forwarding settings in the router.
Then just add the public/outside IP of the internett router as the IP/KNX adapter in ETS and you can program like you where on-site.
regards
Thomas
Threads: 3
By doing so, be sure to disable the port forwarding after, otherwise your KNX network will be available to everyone sniffing the address.
Using a VPN capable modem is a better choice. Or some openvpn client/server so you have a secure connection between your PC and the remote site.
