Multi LogicMachine on same KNX
Hello
In a system since they do not give me access from the various PCs to the LM via network, I will put a logicmachine on each PC, I wanted to know if being all on the same KNX BUS can they create conflicts?
I need to set some particular parameters, or just change the individual KNX addresses.
A thousand thanks
Each LM by default act as IP router it means will transmit telegrams from TP to IP, when more are connected to same TP it will create KNX loop. You can stop it by filter table, or disabling KNX IP or changing multicast.
