Threads: 75
Hello
I have RGBW light and I want to change the icon color based on the RGBW feedback color.
Icon could be like this:
best regards,
Best Regards,
Threads: 43
Set Additional classes to
rgbw and add this to Custom JS:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
function (){
'.rgbw' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
var value =
object.value ;
var r = ((
value >>
24 ) &
0xFF ) /
255 ;
var g = ((
value >>
16 ) &
0xFF ) /
255 ;
var b = ((
value >>
8 ) &
0xFF ) /
255 ;
var w = (
value &
0xFF ) /
255 ;
var a =
0.6 * (
1 - (
1 -
w ) * (
1 -
w ));
var rgb = [
Math.round (((
1 -
a ) *
r +
a ) *
255 ),
Math.round (((
1 -
a ) *
g +
a ) *
255 ),
Math.round (((
1 -
a ) *
b +
a ) *
255 )
el.css (
'background' ,
'rgb(' +
rgb.join (
Icon will be hidden, the square size will be the same as the icon size. RGBW value is converted to RGB.
Threads: 75
11.04.2022, 08:34
(This post was last modified: 11.04.2022, 08:36 by khalil .)
Thanks Admin
But how to deal with different RGB, RGBW data type: objects 3byte RGB, 4byte RGBW, 6byte DALI RGBW.
Also Could we change the background of a circle and other shapes?
Best Regards,
Threads: 43
This will work both 4 and 6 byte RGBW as well as RGB (use
rgb class for it):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
function (){
'.rgbw' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
var value =
object.value ;
var r ,
g ,
b ,
w ;
if (
typeof value ==
'object' ) {
r = (
value.red ||
0 ) /
255 ;
g = (
value.green ||
0 ) /
255 ;
b = (
value.blue ||
0 ) /
255 ;
w = (
value.white ||
0 ) /
255 ;
else {
r = ((
value >>
24 ) &
0xFF ) /
255 ;
g = ((
value >>
16 ) &
0xFF ) /
255 ;
b = ((
value >>
8 ) &
0xFF ) /
255 ;
w = (
value &
0xFF ) /
255 ;
var a =
0.6 * (
1 - (
1 -
w ) * (
1 -
w ));
var rgb = [
Math.round (((
1 -
a ) *
r +
a ) *
255 ),
Math.round (((
1 -
a ) *
g +
a ) *
255 ),
Math.round (((
1 -
a ) *
b +
a ) *
255 )
el.css (
'background' ,
'rgb(' +
rgb.join (
'.rgb' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
el.css (
'background' ,
Scada.getRgbHex (
object.value ));
Shape can be changed via CSS (this will produce a circle):
rgbw {
border-radius :
50% ;
A more complex shape can be done via clip-path:
https://developer.mozilla.org/en-US/docs.../clip-path
Threads: 75
Hello Admin
Is it possible to link the background color with Also the on/off Feedback?
While the DALI RGBW status color stay on its last value even when the unit is off.
Best Regards,
Threads: 43
This can be implemented via a separate virtual object and event script.
Threads: 75
(11.05.2022, 10:31) admin Wrote: This can be implemented via a separate virtual object and event script.
Thanks Admin
If you could share an example I will be thankful.
Best Regards,
Threads: 43
You will need two event scripts. When lamp status (1/1/1) is off then the color status (32/1/1) is black, otherwise color control (1/1/2) value is used.
1. DALI RGBW color object:
1 2 3 4 5 6 7 8 9
on =
grp.getvalue (
'1/1/1' )
if on then
value =
event.getvalue ()
value = {
red =
0 ,
green =
0 ,
blue =
0 ,
white =
0 }
grp.checkupdate (
'32/1/1' ,
value )
2. Lamp on/off object:
1 2 3 4 5 6 7 8 9
on =
event.getvalue ()
if on then
value =
grp.getvalue (
'1/1/2' )
value = {
red =
0 ,
green =
0 ,
blue =
0 ,
white =
0 }
grp.checkupdate (
'32/1/1' ,
value )
Threads: 75
Thanks admin for the hint
I will do it in one script using TAG.
But I noticed that grp.checkupdate/write doesn't work on DT8 color objects, I used that in a resident script and its keep updating each cycle.
Best Regards,
Threads: 43
Yes, there is a bug in checkwrite for complex data types that use table values. Only date and time types are checked correctly.
Threads: 75
(11.04.2022, 08:53) admin Wrote: This will work both 4 and 6 byte RGBW as well as RGB (use rgb class for it):
function (){
'.rgbw' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
var value =
object.value ;
var r ,
g ,
b ,
w ;
if (
typeof value ==
'object' ) {
r = (
value.red ||
0 ) /
255 ;
g = (
value.green ||
0 ) /
255 ;
b = (
value.blue ||
0 ) /
255 ;
w = (
value.white ||
0 ) /
255 ;
else {
r = ((
value >>
24 ) &
0xFF ) /
255 ;
g = ((
value >>
16 ) &
0xFF ) /
255 ;
b = ((
value >>
8 ) &
0xFF ) /
255 ;
w = (
value &
0xFF ) /
255 ;
var a =
0.6 * (
1 - (
1 -
w ) * (
1 -
w ));
var rgb = [
Math.round (((
1 -
a ) *
r +
a ) *
255 ),
Math.round (((
1 -
a ) *
g +
a ) *
255 ),
Math.round (((
1 -
a ) *
b +
a ) *
255 )
el.css (
'background' ,
'rgb(' +
rgb.join (
'.rgb' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
el.css (
'background' ,
Scada.getRgbHex (
object.value ));
rgbw {
border-radius :
50% ;
A more complex shape can be done via clip-path: https://developer.mozilla.org/en-US/docs.../clip-path
Hello Admin
I try to add box-shadow to make the color glow, but how to make it right (depend on the color feedback)?
Best Regards,
Threads: 43
Use this, blur/spread radius (10px 10px) can be changed if needed:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
function (){
'.rgbw' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
var value =
object.value ;
var r ,
g ,
b ,
w ;
if (
typeof value ==
'object' ) {
r = (
value.red ||
0 ) /
255 ;
g = (
value.green ||
0 ) /
255 ;
b = (
value.blue ||
0 ) /
255 ;
w = (
value.white ||
0 ) /
255 ;
else {
r = ((
value >>
24 ) &
0xFF ) /
255 ;
g = ((
value >>
16 ) &
0xFF ) /
255 ;
b = ((
value >>
8 ) &
0xFF ) /
255 ;
w = (
value &
0xFF ) /
255 ;
var a =
0.6 * (
1 - (
1 -
w ) * (
1 -
w ));
var rgb = [
Math.round (((
1 -
a ) *
r +
a ) *
255 ),
Math.round (((
1 -
a ) *
g +
a ) *
255 ),
Math.round (((
1 -
a ) *
b +
a ) *
255 )
var bg =
'rgb(' +
rgb.join (
el
css (
'background' ,
bg )
css (
'box-shadow' ,
'0 0 10px 10px ' +
bg );
'.rgb' ).
each (
function (
index ,
el ) {
var $
el = $(
el );
var addr = $
el.data (
'status-object' );
el.find (
'img' ).
css (
'visibility' ,
'hidden' );
grp.listen (
addr ,
function (
object ) {
var bg =
Scada.getRgbHex (
object.value );
el
css (
'background' ,
bg )
css (
'box-shadow' ,
'0 0 10px 10px ' +
bg );
Threads: 75
Great
Thank you very much
Best Regards,
