Visibility or active/clickable by object status value
Is try to active/show and desactivare/hide a command button icon on the basis of the status object value.
Ideally, the element is always visible (adding an On, active icon and an Off, passive/greyed icon), but only can be selected/activated/clicked when value of status object is true
I added JS, but doesn't seem to do the trick
$(function() {
  $('.hidden-by-value').each(function(_, el) {
    var addr = $(el).data('object');
    if (addr) {
      grp.listen(addr, function(obj) {
        var value = obj.value;
        $(el).css('visibility', if value {'visible'} else {'hidden'});
Do I overlook something?
is 'object' correct? Or is this the main abject, and not the status object?
Thx
Don't ask what we can do in KNX but wonder what we can't - www.KNXlogic.eu
You have a syntax error, it should be:
$(function() {
    if (addr) {
        $(el).css('visibility', value ? 'visible' : 'hidden');
Thx for that
It's still not working correctly. In the inspector now the 'visibility' tag is indeed there. But the visibility doesn't update when a new value/telegram appears on the sts group object.
I added a console.log(value), and only one value is logged: at page load, not when the status object value changes
Listener is attached to the main (control) object. Change 'object' to 'status-object' on line 3 to listen to the status object instead.
(20.05.2022, 15:07)admin Wrote: Listener is attached to the main (control) object. Change 'object' to 'status-object' on line 3 to listen to the status object instead.
that's exacctly what I just noticed: the addr is the main object not the status object.
works like a charm now.
Thx admin, and have a nice weekend
