ZigBee Device won't Update BUS
Hallo,
I have a tradfri 30W dimmer correctly paired with my LM5 Lite (i.mx6)
Device works perfectly but It looks not to update correctly the bus:
I have a dimmer button configured and I am ussumed to get the state change on the bus, but this does not hammpend.
Groups are connected correctly, ETS setup if fine, but I do not get events on bus.
No current dim % (1Byte)
No state feedback (1 bit)
this is the current config
Manufacturer: IKEA of Sweden Model: TRADFRI Driver 30W Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightLink (4096) - 64636 Output clusters - Scenes (5) - Ota (25) - PollCtrl (32) - LightLink (4096) Endpoint 242 Profile: 41440 Input clusters - GreenPwr (33) Output clusters - GreenPwr (33)
commands are received and executed correctly, but no fedback at all Sad
thanks
marco
Which App version are you using? Support for TRADFRI Driver 30W has been added recently. You might need to reset the device and pair it again for status feedback to work. In some case ZigBee device firmware upgrade is needed. Unfortunately at this moment LM does not support firmware upgrades for Ikea devices, you need Ikea gateway for this.
