Hey guys!
I have LM5 reactor with a very strange behaviour from last weekend. From Saturday morning it was unreachable in LAN and it wasn't working.
Disconnecting from power doesn't help.
On Tuesday morning it surprisingly appeared without any help but on the evening once again it died. Today is Wednesday and a few minutes ago it appeared once again.
At this moment this device has very little to do, I've passed all cpu-consuming scripts to another device and most of the time it's below 0.3. It's used as also a KNX IP router and every 5 minutes I'm fetching all objects from another device.
When I'm checking System logs it's also strange because it shows logs from today and 1 January.
I know that this device is a version which isn't relying on SD card for system purposes so it shouldn't be the case where the source of the problem is the SD card which is readonly.
From Alerts tab I see that it started precisely on:
01.07.2022 08:00:16
02.07.2022 06:30:17
02.07.2022 08:00:17
06.07.2022 09:48:16
But I'm sure that from yesterday at least 19:00 it was also not reachable so I'm not sure if above logs are complete.
How can I debug this or check what is wrong with this device?
01.07.2022 08:00:16
02.07.2022 06:30:17
02.07.2022 08:00:17
06.07.2022 09:48:16
Done is better than perfect
