strange backslash when json.write
Hi !
I am working on LM app development and below is the index.lp code.
From the commandline I can use the endpoint like this , with a request body. It returns the result like this : {"results":[{"alias":"6\/6\/1","value":true}]}
Is there a way to remove the backslash in from the result json string ?
Thank you !
http://id:pass@LM local IP/apps/data/logic-machine/index.lp
    "commands":[
            "alias":"6/6/1",
            "value":true
<?   require('json')   require('apps')   params = ngx.req.get_body_data()   params = json.pdecode(params)   require('custom.utils')   results = {}   if params ~= nil then     for index, command in ipairs(params.commands) do       if type(command.alias) ~= nil or type(command.value) ~= nil then         res = grp.write(command.alias, command.value) or false         table.insert(results, {value = res, alias = command.alias})       end     end     results = {       results = results     }     write(json.encode(results))   end ?>
No need to remove this backslashes. This is allowed by the JSON specification. Some libraries escape forward slashes and some do not.
Thank you admin for your help always !
Oh I understand ... my client want them without backslashes....
Is there any way not to escape this ?
Or maybe I need to ask them to unescape them when they decode json ?
What programming language/library is your client using? Nearly all of them can handle such escape sequence.
Thank you admin! I think it's Go lang
Go JSON parser will handle it correctly.
Escaping slashes can be removed like this but it's a pointless operation Smile
results = json.encode(results) results = results:gsub('\\/', '/') write(results)
Thank you admin !!
I will talk with my client about this (:
Your solution worked also !
