strange backslash when json.write
Hi !
I am working on LM app development and below is the index.lp code.
From the commandline I can use the endpoint like this , with a request body. It returns the result like this : {"results":[{"alias":"6\/6\/1","value":true}]}
Is there a way to remove the backslash in from the result json string ?
Thank you !
http://id:pass@LM local IP/apps/data/logic-machine/index.lp
    "commands":[
            "alias":"6/6/1",
            "value":true
  require('json')
  require('apps')
  params = ngx.req.get_body_data()
  params = json.pdecode(params)
  require('custom.utils')
  results = {}
  if params ~= nil then
    for index, command in ipairs(params.commands) do
      if type(command.alias) ~= nil or type(command.value) ~= nil then
        res = grp.write(command.alias, command.value) or false
        table.insert(results, {value = res, alias = command.alias})
    results = {
      results = results
    write(json.encode(results))
No need to remove this backslashes. This is allowed by the JSON specification. Some libraries escape forward slashes and some do not.
Thank you admin for your help always !
Oh I understand ... my client want them without backslashes....
Is there any way not to escape this ?
Or maybe I need to ask them to unescape them when they decode json ?
What programming language/library is your client using? Nearly all of them can handle such escape sequence.
Thank you admin! I think it's Go lang
Go JSON parser will handle it correctly.
Escaping slashes can be removed like this but it's a pointless operation Smile
results = json.encode(results)
results = results:gsub('\\/', '/')
write(results)
Thank you admin !!
I will talk with my client about this (:
Your solution worked also !
