CSS Spin
Hello
How to make this CSS Spin Work for Read only objects
Its work for non read only objects
/* CSS Spin Animation with JS */ .spin-animation.ok-a.ok-b {   animation: spin 0.5s infinite linear; } @keyframes spin {   from {     transform:rotate(0deg);   }   to {     transform:rotate(360deg);   } }
Best Regards,
Read-only disables transform modifications. Add this to Custom JS to fix this issue:
$(function() {   $('.spin-animation.item-read-only')     .removeClass('item-read-only')     .css('pointer-events', 'none'); });
(05.09.2022, 10:26)admin Wrote: Read-only disables transform modifications. Add this to Custom JS to fix this issue:
Thank you admin
Works good Smile
Best Regards,
Hello admin,
Fan Didn't Spin in the first time, after second change or browser refresh it become ok!
here is the JS I used:
// Spin/High Speed Fan $(function(){   if (window.grp) {     function listen(i) {       grp.listen('1/7/' + i, function(object) {           $('.spin-animation.item-read-only')                     .removeClass('item-read-only')                     .css('pointer-events', 'none');           $('.spin-' +i).toggleClass('spin-animation', object.value == true);       });     }         for (var i = 1; i <= 40; i++) {       listen(i);     }   } });
Another issue I faced:
I used This Rotate JS Code:
// Rotate $(function(){   $('[class*=rotate-]').each(function(index, el) {     var match = el.className.match(/rotate\-(\d+)/);     el.style.transform = 'rotate(' + match[1] + 'deg';   }); });
But I added another JS Code to Enable/Disable read only property, Because these objects controlled by Motion sensors but I want to give the user control in case of Motion failure.
But when objects changed to Read only by the following JS; rotate malfunction
$(function(){    grp.listen('50/5/21', function(object) {       if (object.value == true ) {          $(".lockbyknx").addClass("item-read-only");       } else if (object.value == false ) {          $(".lockbyknx").removeClass("item-read-only");       }    }); });
Best Regards,
Instead of using item-read-only class you can just block pointer events via CSS:
$(function(){   grp.listen('50/5/21', function(object) {     $('.lockbyknx').css('pointer-events', object.value ? 'none' : '');   }); });
Thank admin
and regarding the spin issue how to solve it?
Best Regards,
Try this:
$(function(){   if (window.grp) {     function listen(i) {       grp.listen('1/7/' + i, function(object) {           $('.spin-' +i).toggleClass('spin-animation', object.value == true);           $('.spin-animation.item-read-only')                     .removeClass('item-read-only')                     .css('pointer-events', 'none');       });     }         for (var i = 1; i <= 40; i++) {       listen(i);     }   } });
Thanks admin
I will test in the next site visit.
Best Regards,
