Integration with 2N doorphone
maybe do you know if there is a possibility to connect LM with 2N doorphone with video+audio(RTSP) exchange?
In the manual I have such information that for such communication I must send RTSP commands:
rtsp://doorphone_IP/h264_stream
rtsp://doorphone_IP/mpeg_stream
rtsp://doorphone_IP/mjpeg_stream
Is it possible via LM now?
Unfortunately, RTSP is not supported by any browser natively, so it's not possible to display it in the visualization directly.
This commands works very nice for camera image streaming:
http://doorphone_IP/enu/cameraWxH.jpg?fps=N
WxH - WIDTHxHEIGHT (160X120, 320X240, 640X480, 176x144, 322x272, 352x288 and 1280x960 but ONLY FOR Mpix cameras)
N - FPS (e.g. 1, 5 or 25)
And also I am using the button for opening the doors and garage doors and switching light.
Do you use http commands to open the door or switch lights?
Yes, this is based on the library from Schneider:
AN036_Room_Control_and_Door_Entry_Solution_interoperability_v1.0
But unfortunately in this library there isn't any integration with doorphone image via Spacelynk so I must prepare this by myself. From licensing side my client bought only license for "Enhanced integration".
