Threads: 16
(05.07.2022, 06:36)admin Wrote: Add before multiply function:
Code: function onofftobool(payload)
return tostring(payload):lower() == 'on'
Then modify mqtt_to_object_conv table:
Code: mqtt_to_object_conv = {
['shellies/shellyplug-s-D9AA39/relay/0'] = onofftobool,
Thanks!
Threads: 16
13.10.2022, 14:26
(This post was last modified: 13.10.2022, 14:28 by a455115.)
(20.06.2022, 13:14)a455115 Wrote: Code: if not broker then
broker = '127.0.0.1'
function multiply(mult)
return function(value)
local num = tonumber(value)
if num then
return num * mult
return value
-- topic to object map
mqtt_to_object = {
['shellies/shellyplug-s-D9AA39/relay/0'] = '32/1/1',
['shellies/shellyplug-s-D9AA39/temperature'] = '32/1/2',
-- optional topic value conversion function
['shellies/shellyplug-s-D9AA39/relay/0'] = multiply(1),
['shellies/shellyplug-s-D9AA39/temperature'] = multiply(1),
-- object to topic map
object_to_mqtt = {
-- ['1/1/1'] = 'out/topic1',
-- ['1/1/2'] = 'out/topic2',
datatypes = {}
grp.sender = 'mq'
require('socket')
for addr, _ in pairs(object_to_mqtt) do
local obj = grp.find(addr)
if obj then
datatypes[ addr ] = obj.datatype
mclient = require('mosquitto').new()
mclient.ON_CONNECT = function(res, ...)
log('mqtt connect status', res, ...)
if res then
for topic, _ in pairs(mqtt_to_object) do
mclient:subscribe(topic)
mclient:disconnect()
mclient.ON_MESSAGE = function(mid, topic, payload)
local addr = mqtt_to_object[ topic ]
if addr then
local fn = mqtt_to_object_conv[ topic ]
if fn then
payload = fn(payload)
grp.write(addr, payload)
mclient.ON_DISCONNECT = function(...)
log('mqtt disconnect', ...)
mclientfd = nil
function mconnect()
local fd
mclient:connect(broker)
fd = mclient:socket()
-- fd ref is valid
if fd then
mclientfd = fd
mconnect()
function publishvalue(event)
-- message from us or client is not connected
if event.sender == 'mq' or not mclientfd then
return
local addr = event.dst
local dpt = datatypes[ addr ]
local topic = object_to_mqtt[ addr ]
-- unknown object
if not dpt or not topic then
return
local value = busdatatype.decode(event.datahex, dpt)
if value ~= nil then
if type(value) == 'boolean' then
value = value and 1 or 0
mclient:publish(topic, tostring(value))
lbclient = require('localbus').new(1)
lbclient:sethandler('groupwrite', publishvalue)
lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')
-- run timer every 5 seconds
timer = require('timerfd').new(5)
timerfd = socket.fdmaskset(timer:getfd(), 'r')
-- mqtt connected
if mclientfd then
mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')
res, lbclientstat, timerstat, mclientstat =
socket.selectfds(10, lbclientfd, timerfd, mclientfdset)
-- mqtt not connected
res, lbclientstat, timerstat =
socket.selectfds(10, lbclientfd, timerfd)
if mclientfd and mclientstat then
if socket.fdmaskread(mclientstat) then
mclient:loop_read()
if socket.fdmaskwrite(mclientstat) then
mclient:loop_write()
if lbclientstat then
lbclient:step()
if timerstat then
-- clear armed timer
timer:read()
if mclientfd then
mclient:loop_misc()
mconnect()
Hi admin,
How do I convert directly from the code to get a specific parameter from the Json it returns? For an example of a specific topic it returns json to me
shellies/shellytrv-14B457E5C2C8/info
return
{"tmp": {"value":24.5,"units": "C","is_valid": true},"target_t":{"enabled":false,"value":22.0,"units":"C "},"temperature_offset":0.0,"bat":99}
I only want to extract from it:
target_t - value - 1/1/1
bat - 1/1/2
How can I extract only this with the above code?
Threads: 43
Use this (1/1/1 is battery object, 1/1/2 is target temperature value object):
Code: mqtt_to_object = {
['shellies/shellytrv-14B457E5C2C8/info'] = '1/1/1',
['shellies/shellytrv-14B457E5C2C8/info'] = function(payload)
local data = require('json').pdecode(payload)
if type(data) == 'table' then
grp.write('1/1/2', data.target_t.value)
return data.bat
Threads: 16
(14.10.2022, 06:17)admin Wrote: Use this (1/1/1 is battery object, 1/1/2 is target temperature value object):
return data.bat
Hi admin,
Data.target_t.value does not work. This is a log from data, and from data.thermostats, how should I get the target_t ? If I have many shelits for each, should I add it this way?
Code: log (data)
["ps_mode"]
* number: 0
["thermostats"]
* table:
[1]
* table:
["tmp"]
* table:
["is_valid"]
* bool: true
["units"]
* string: C
["value"]
* number: 24.7
["pos"]
* number: 50
["target_t"]
* table:
["value_op"]
* number: 8
["enabled"]
* bool: false
["units"]
* string: C
["value"]
* number: 22
["window_open"]
* bool: false
["boost_minutes"]
* number: 0
["schedule"]
* bool: false
["schedule_profile"]
* number: 1
["fs_free"]
* number: 59376
["wifi_sta"]
* table:
["connected"]
* bool: true
["rssi"]
* number: -59
["ssid"]
* string: Project Solutions
["ip"]
* string: 10.0.5.105
["dbg_flags"]
* number: 0
["mac"]
* string: 14B457E5C2C8
["cloud"]
* table:
["connected"]
* bool: false
["enabled"]
* bool: false
["time"]
* string: 12:47
["update"]
* table:
["new_version"]
* string: 20220811-152343/v2.1.8@5afc928c
["old_version"]
["status"]
* string: unknown
["beta_version"]
* userdata: NULL
["has_update"]
* bool: false
["bat"]
* table:
["voltage"]
* number: 4.077
["value"]
* number: 99
["unixtime"]
* number: 1666000030
["ram_total"]
* number: 97280
["fw_info"]
* table:
["fw"]
["device"]
* string: shellytrv-14B457E5C2C8
["calibrated"]
* bool: true
["uptime"]
* number: 5326
["charger"]
* bool: false
["ram_free"]
* number: 22568
["actions_stats"]
* table:
["skipped"]
* number: 0
["serial"]
* number: 0
["mqtt"]
* table:
["connected"]
* bool: true
["has_update"]
* bool: false
["cfg_changed_cnt"]
* number: 0
["fs_size"]
* number: 65536
log(data.thermostats)
[1]
* table:
["tmp"]
* table:
["is_valid"]
* bool: true
["units"]
* string: C
["value"]
* number: 24.7
["pos"]
* number: 50
["target_t"]
* table:
["value_op"]
* number: 8
["enabled"]
* bool: false
["units"]
* string: C
["value"]
* number: 22
["window_open"]
* bool: false
["boost_minutes"]
* number: 0
["schedule"]
* bool: false
* number: 1
Threads: 43
Try this:
['shellies/shellytrv-14B457E5C2C8/info'] = '1/1/1', -- battery level
['shellies/shellytrv-ABC/info'] = '2/1/1', -- battery level
['shellies/shellytrv-DEF/info'] = '3/1/1', -- battery level
function conv_therm(payload, target_t_addr)
grp.write(target_t_addr, data.thermostats[1].target_t.value)
return data.bat.value
return conv_therm(payload, '1/1/2') -- target temp
end,
['shellies/shellytrv-ABC/info'] = function(payload)
return conv_therm(payload, '2/1/2') -- target temp
end,
['shellies/shellytrv-DEF/info'] = function(payload)
return conv_therm(payload, '3/1/2') -- target temp
Threads: 16
(17.10.2022, 10:00)admin Wrote: Try this:
end,
end,
It works, thanks a lot!
Threads: 16
What is the maximum number of objects/devices Logic Machine can work with without problems? I want to hook up an apartment complex with shelly.
Threads: 43
It should handle several hundred devices.
Threads: 65
Hi, with the above code, you use broadcast topic "shellies". If I use a topic set in a device, eg a ShellyPluss1 (relay) eith add-on module, how can i sort the different values on the same topic?
I made this based on the above, but it only works on th ebinary status object, not temperature:
Code: function conv_shellyRelay(payload, numberRel, target_s_addr)
grp.write(target_s_addr, data["params"][numberRel]["output"])
log(data.bat.value)
function conv_shellyTemp(payload, numberTemp, target_t_addr)
log(data["params"][numberTemp]["tC"])
grp.write(target_t_addr, data["params"][numberTemp]["tC"])
mqtt_to_object = {
['Shelly/events/rpc'] = '33/1/8', -- Temperature 1
['Shelly/events/rpc'] = '33/1/9', -- Status relay
['Shelly/events/rpc'] = '33/1/10',-- Temperature 2
['Shelly/events/rpc'] = function(payload)
return conv_shellyTemp(payload,"temperature:100", '33/1/8')
end,
return conv_shellyTemp(payload,"temperature:101", '33/1/10')
end,
return conv_shellyRelay(payload,"switch:0", '33/1/9')
end,
object_to_mqtt = {
['33/1/7'] = 'Shelly/command/switch:0',
Threads: 43
You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated.
Threads: 65
03.01.2024, 10:26
(This post was last modified: 03.01.2024, 11:05 by tomnord.)
(03.01.2024, 10:19)admin Wrote: You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated.
Ok, I was afraid of that. So i need to make logic that only reads topic once, and then sorts out the different values I'm looking for.
So I made a function to look up certain names in the table, is there any way to have the mqtt_to_object run without a GA attached? It will only run the first grp.write:
Code: function conv_shellyTemp(payload)
function tableHasKey(table, prefix)
for key, _ in pairs(table) do
--log(key)
if string.match(key, prefix) then
return true
return false
if tableHasKey(data["params"],"temperature") then
grp.write('33/1/8', data["params"]["temperature:100"]["tC"])
grp.write('33/1/10', data["params"]["temperature:101"]["tC"])
elseif
tableHasKey(data["params"],"switch") then
grp.write('33/1/9', data["params"]["switch:0"]["output"])
log("no data")
Threads: 65
(03.01.2024, 10:26)tomnord Wrote: (03.01.2024, 10:19)admin Wrote: You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated.
--log(key)
return true
return false
elseif
log("no data")
Figured it out, needed to activate status sending.
But I would lik eto be able to use the GetStatus function from, it seems to be a request that does not need a input.
https://shelly-api-docs.shelly.cloud/gen...us-example
Threads: 43
You can attach topic to a dummy object. If the conversion function does not return anything the grp.write won't happen anyway.
For HTTP requests search the forum, there are many examples that can be adapted.
Threads: 65
Code: ["thermostats"]
* table:
[1]
* table:
["valve_min_percent"]
* number: 0
["t_auto"]
* table:
["enabled"]
* bool: true
["target_t"]
* table:
["units"]
* string: C
["value_op"]
* number: 8
["enabled"]
* bool: true
["accelerated_heating"]
* bool: true
["value"]
* number: 7
["extra_pressure"]
* bool: false
["calibration_correction"]
* bool: true
["schedule_profile_names"]
* table:
[1]
* string: Livingroom
[2]
* string: Livingroom 1
[3]
* string: Bedroom
[4]
* string: Bedroom 1
[5]
* string: Holiday
* number: 1
["open_window_report"]
* bool: false
["boost_minutes"]
* number: 30
["valve_min_report"]
* number: 1
["force_close"]
* bool: false
["schedule_rules"]
* table:
[1]
* string: 0600-0123456-23
[2]
* string: 2300-0123456-18
["ext_t"]
* table:
["floor_heating"]
* bool: false
["enabled"]
* bool: true
["schedule"]
* bool: false
["temperature_offset"]
* number: 0
I am trying to write to the object "temperature_offset" but i can not get the syntax right.
"'shellies/TRV_ROM1/settings/thermostats . .. "
It is stated as a parameter in the documentation for mqtt.
https://shelly-api-docs.shelly.cloud/gen...rmostats-0
The http command is:
Code: http://10.xxx.xxx.xxx/ext_t?temp=measured t°
Threads: 43
Try http://IP/settings/thermostats/0?temperature_offset=5
If this does not work then contact Shelly support.
Threads: 65
shellies/TRV_ROM1/thermostat/0/command/ext_t
This worked over MQTT. had to dig in the docu, TRV needed to be set as Floor_heating to use external value.
Quick question, can I have several MQTT scripts running, e.g one for each component? Or should I run all in one script?
Threads: 43
You can use multiple scripts but it makes more sense to handle everything in a single script.
Threads: 65
YEah, I guess. just thought it would be easier to auto generate GA's in separate scrips.
