05.07.2022, 10:40
Shelly - WiFi IoT-Devices
(20.06.2022, 13:14)a455115 Wrote:Hi admin, How do I convert directly from the code to get a specific parameter from the Json it returns? For an example of a specific topic it returns json to me shellies/shellytrv-14B457E5C2C8/info return {"tmp": {"value":24.5,"units": "C","is_valid": true},"target_t":{"enabled":false,"value":22.0,"units":"C "},"temperature_offset":0.0,"bat":99} I only want to extract from it: target_t - value - 1/1/1 bat - 1/1/2 How can I extract only this with the above code?
14.10.2022, 06:17
Use this (1/1/1 is battery object, 1/1/2 is target temperature value object):
Code: mqtt_to_object = {
['shellies/shellytrv-14B457E5C2C8/info'] = '1/1/1',
mqtt_to_object_conv = {
['shellies/shellytrv-14B457E5C2C8/info'] = function(payload)
local data = require('json').pdecode(payload)
if type(data) == 'table' then
grp.write('1/1/2', data.target_t.value)
return data.bat
17.10.2022, 09:53
(14.10.2022, 06:17)admin Wrote: Use this (1/1/1 is battery object, 1/1/2 is target temperature value object):Hi admin, Data.target_t.value does not work. This is a log from data, and from data.thermostats, how should I get the target_t ? If I have many shelits for each, should I add it this way? Code: log (data)
["ps_mode"]
* number: 0
["thermostats"]
* table:
[1]
* table:
["tmp"]
* table:
["is_valid"]
* bool: true
["units"]
* string: C
["value"]
* number: 24.7
["pos"]
* number: 50
["target_t"]
* table:
["value_op"]
* number: 8
["enabled"]
* bool: false
["units"]
* string: C
["value"]
* number: 22
["window_open"]
* bool: false
["boost_minutes"]
* number: 0
["schedule"]
* bool: false
["schedule_profile"]
* number: 1
["fs_free"]
* number: 59376
["wifi_sta"]
* table:
["connected"]
* bool: true
["rssi"]
* number: -59
["ssid"]
* string: Project Solutions
["ip"]
* string: 10.0.5.105
["dbg_flags"]
* number: 0
["mac"]
* string: 14B457E5C2C8
["cloud"]
* table:
["connected"]
* bool: false
["enabled"]
* bool: false
["time"]
* string: 12:47
["update"]
* table:
["new_version"]
* string: 20220811-152343/v2.1.8@5afc928c
["old_version"]
["status"]
* string: unknown
["beta_version"]
* userdata: NULL
["has_update"]
* bool: false
["bat"]
* table:
["voltage"]
* number: 4.077
["value"]
* number: 99
["unixtime"]
* number: 1666000030
["ram_total"]
* number: 97280
["fw_info"]
* table:
["fw"]
["device"]
* string: shellytrv-14B457E5C2C8
["calibrated"]
* bool: true
["uptime"]
* number: 5326
["charger"]
* bool: false
["ram_free"]
* number: 22568
["actions_stats"]
* table:
["skipped"]
* number: 0
["serial"]
* number: 0
["mqtt"]
* table:
["connected"]
* bool: true
["has_update"]
* bool: false
["cfg_changed_cnt"]
* number: 0
["fs_size"]
* number: 65536
log(data.thermostats)
[1]
* table:
["tmp"]
* table:
["is_valid"]
* bool: true
["units"]
* string: C
["value"]
* number: 24.7
["pos"]
* number: 50
["target_t"]
* table:
["value_op"]
* number: 8
["enabled"]
* bool: false
["units"]
* string: C
["value"]
* number: 22
["window_open"]
* bool: false
["boost_minutes"]
* number: 0
["schedule"]
* bool: false
* number: 1
17.10.2022, 10:00
Try this:
['shellies/shellytrv-14B457E5C2C8/info'] = '1/1/1', -- battery level
['shellies/shellytrv-ABC/info'] = '2/1/1', -- battery level
['shellies/shellytrv-DEF/info'] = '3/1/1', -- battery level
function conv_therm(payload, target_t_addr)
grp.write(target_t_addr, data.thermostats[1].target_t.value)
return data.bat.value
return conv_therm(payload, '1/1/2') -- target temp
end,
['shellies/shellytrv-ABC/info'] = function(payload)
return conv_therm(payload, '2/1/2') -- target temp
end,
['shellies/shellytrv-DEF/info'] = function(payload)
return conv_therm(payload, '3/1/2') -- target temp
17.10.2022, 14:51
(17.10.2022, 10:00)admin Wrote: Try this: It works, thanks a lot!
20.10.2022, 06:48
What is the maximum number of objects/devices Logic Machine can work with without problems? I want to hook up an apartment complex with shelly.
20.10.2022, 07:44
It should handle several hundred devices.
03.01.2024, 10:12
Hi, with the above code, you use broadcast topic "shellies". If I use a topic set in a device, eg a ShellyPluss1 (relay) eith add-on module, how can i sort the different values on the same topic?
I made this based on the above, but it only works on th ebinary status object, not temperature: Code: function conv_shellyRelay(payload, numberRel, target_s_addr)
grp.write(target_s_addr, data["params"][numberRel]["output"])
log(data.bat.value)
function conv_shellyTemp(payload, numberTemp, target_t_addr)
log(data["params"][numberTemp]["tC"])
grp.write(target_t_addr, data["params"][numberTemp]["tC"])
-- topic to object map
mqtt_to_object = {
['Shelly/events/rpc'] = '33/1/8', -- Temperature 1
['Shelly/events/rpc'] = '33/1/9', -- Status relay
['Shelly/events/rpc'] = '33/1/10',-- Temperature 2
['Shelly/events/rpc'] = function(payload)
return conv_shellyTemp(payload,"temperature:100", '33/1/8')
end,
return conv_shellyTemp(payload,"temperature:101", '33/1/10')
end,
return conv_shellyRelay(payload,"switch:0", '33/1/9')
end,
-- object to topic map
object_to_mqtt = {
['33/1/7'] = 'Shelly/command/switch:0',
03.01.2024, 10:19
You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated.
(03.01.2024, 10:19)admin Wrote: You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated. Ok, I was afraid of that. So i need to make logic that only reads topic once, and then sorts out the different values I'm looking for. So I made a function to look up certain names in the table, is there any way to have the mqtt_to_object run without a GA attached? It will only run the first grp.write: Code: function conv_shellyTemp(payload)
function tableHasKey(table, prefix)
for key, _ in pairs(table) do
--log(key)
if string.match(key, prefix) then
return true
return false
if tableHasKey(data["params"],"temperature") then
grp.write('33/1/8', data["params"]["temperature:100"]["tC"])
grp.write('33/1/10', data["params"]["temperature:101"]["tC"])
elseif
tableHasKey(data["params"],"switch") then
grp.write('33/1/9', data["params"]["switch:0"]["output"])
log("no data")
03.01.2024, 14:46
(03.01.2024, 10:26)tomnord Wrote:(03.01.2024, 10:19)admin Wrote: You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated. Figured it out, needed to activate status sending. But I would lik eto be able to use the GetStatus function from, it seems to be a request that does not need a input. https://shelly-api-docs.shelly.cloud/gen...us-example
03.01.2024, 15:00
You can attach topic to a dummy object. If the conversion function does not return anything the grp.write won't happen anyway.
For HTTP requests search the forum, there are many examples that can be adapted.
16.01.2024, 08:51
Code: ["thermostats"]
* table:
[1]
* table:
["valve_min_percent"]
* number: 0
["t_auto"]
* table:
["enabled"]
* bool: true
["target_t"]
* table:
["units"]
* string: C
["value_op"]
* number: 8
["enabled"]
* bool: true
["accelerated_heating"]
* bool: true
["value"]
* number: 7
["extra_pressure"]
* bool: false
["calibration_correction"]
* bool: true
["schedule_profile_names"]
* table:
[1]
* string: Livingroom
[2]
* string: Livingroom 1
[3]
* string: Bedroom
[4]
* string: Bedroom 1
[5]
* string: Holiday
* number: 1
["open_window_report"]
* bool: false
["boost_minutes"]
* number: 30
["valve_min_report"]
* number: 1
["force_close"]
* bool: false
["schedule_rules"]
* table:
[1]
* string: 0600-0123456-23
[2]
* string: 2300-0123456-18
["ext_t"]
* table:
["floor_heating"]
* bool: false
["enabled"]
* bool: true
["schedule"]
* bool: false
["temperature_offset"]
* number: 0I am trying to write to the object "temperature_offset" but i can not get the syntax right. "'shellies/TRV_ROM1/settings/thermostats . .. " It is stated as a parameter in the documentation for mqtt. https://shelly-api-docs.shelly.cloud/gen...rmostats-0 The http command is: Code: http://10.xxx.xxx.xxx/ext_t?temp=measured t°
16.01.2024, 09:03
Try http://IP/settings/thermostats/0?temperature_offset=5
If this does not work then contact Shelly support.
16.01.2024, 09:49
shellies/TRV_ROM1/thermostat/0/command/ext_t
This worked over MQTT. had to dig in the docu, TRV needed to be set as Floor_heating to use external value. Quick question, can I have several MQTT scripts running, e.g one for each component? Or should I run all in one script?
16.01.2024, 09:50
You can use multiple scripts but it makes more sense to handle everything in a single script.
16.01.2024, 09:54
YEah, I guess. just thought it would be easier to auto generate GA's in separate scrips.
