28.11.2022, 07:48
		Hello
Is it possible to downgrade SL firmware?
and for which versions?
Best Regards,
					SL Firmware downgrade
		28.11.2022, 07:48
		Hello  Is it possible to downgrade SL firmware? and for which versions?
Best Regards,
		28.11.2022, 07:57
		Firmware downgrade is generally not supported. You can install an older version via recovery but the backup from a newer version might not work. Why do you want to do it?
		28.11.2022, 08:37
	 (28.11.2022, 07:57)admin Wrote: Firmware downgrade is generally not supported. You can install an older version via recovery but the backup from a newer version might not work. Why do you want to do it? I have ETS commissioning issue which was not exist before the upgrade. I upgrade to V2.6.0 to still have remote commission via port 3671. but the issue after upgrade is that I cannot download to devices support KNX secure, while KNX secure deactivated.
Best Regards,
		11.12.2022, 10:37
		Hi there, Is there a solution for secure and working KNX IP Tunneling over internet with ETS6 on firmware 2.8.0 for SL or Wiser? PS: Client router is configured with open 3671 for the public IP at my office. Best,
		11.12.2022, 14:08
		No, and there will never come a solution for open ports on 3671 as this is considered as a serious cyber security leak. If you want to connect to a remote site you need a secure connection to that site and can be done by VPN router or equal solution. We are looking to provide such a solution over our cloud platform but this is not committed yet and there is nothing in development at the moment. |
