23.12.2022, 12:49
Can someone help me to set up 1-Wire sensors? I'm not very familiar with the LM yet. Thanks
1-Wire Beginner
23.12.2022, 12:49
23.12.2022, 12:54
Sensors are discovered automatically once connected to 1-Wire bus. After that you can map sensor values to LM objects.
23.12.2022, 12:59
(This post was last modified: 23.12.2022, 13:00 by blackheath.)
OK. will be found automatically. but where can I find the LM objects? would like to bring this into the KNX.
can i find instructions or screenshots somewhere?
23.12.2022, 13:03
23.12.2022, 13:08
thank, knx is for me ok, but where can I find the 1-Wire sensors and how do I link them to KNX?
sorry, but beginner ;-)
23.12.2022, 13:10
Do you have LM with 1-wire interface on it?
23.12.2022, 13:17
no, 1-Wire Scheider Electric Wiser for KNX 1. Generation
23.12.2022, 13:18
Wiser for KNX does not have this functionality, you must buy LM with 1-wire support and then all will be very clear.
23.12.2022, 13:21
only usb interface
23.12.2022, 13:29
(This post was last modified: 23.12.2022, 13:29 by blackheath.)
shame, had understood that should go with a script
thanks
24.12.2022, 07:17
There is no 1-wire interface (the physical connection of the wire) available on the Wiser for KNX so a 1-wire device cannot be connected to a Wiser for KNX controller, therefore you need a certain LM model with the physical interface.
