rs232 active?
Hi i have  LM5p2-DR
HW: LM5 M4 (imx6) SW: 20211215
i am attempting to use the rs232 port, '/dev/RS232'  when i navigate to the utilities, system status, serial ports,  only /dev/RS485-1 and  /dev/RS485-2 are showing?
i should have  /dev/RS485-1,  /dev/RS485-2,  /dev/RS485-3  /dev/RS232 ??
is there anything to enable or configure to use the RS232 port, i have tried the below code, or maybe i have something else wrong?
port = serial.open('/dev/RS232', { baudrate = 9600, parity = 'even', duplex = 'full' }) log(port)
but port is always nil so i assume  '/dev/RS232' never is opened?
x = io.exists('/dev/RS485-1')
x returns true
but x = io.exists('/dev/RS232')
x returns false
Wrong firmware. You need to install LM5 Lite + Ext.
(26.01.2023, 06:00)admin Wrote: Wrong firmware. You need to install LM5 Lite + Ext.
Thought it might be,
Many thanks all sorted now.
