2byte object over jpg icon
I'm displaying a 2-byte object over an icon, on the visualization editor the object is on the TOP of the icon as it should be but on the SCADA page the object will go below the icon as you can see attached.
NB: I didn't have the problem on another LM5 also tried other browsers
The same type elements have a random position over each other. It is even like in your example that editor has it differently than visu. Work around is by putting one object on layout and second on plan then the one on plan always will be above. You can also try to add z-index, see here https://forum.logicmachine.net/showthrea...8#pid28008
It is not about SVG only if it is a object. Plan elements are different types, object, link, text label, image etc. Each type regardless of icon selected has no priority which one is above each other. Only different types got this defined.
(03.02.2023, 09:08)Daniel Wrote: It is not about SVG only if it is a object. Plan elements are different types, object, link, text label, image etc. Each type regardless of icon selected has no priority which one is above each other. Only different types got this defined.
got you, but none of that helped Sad
Use layout and that will do
(03.02.2023, 09:12)Daniel Wrote: Use layout and that will do
nope,
One should be on layout and second on plan. The one on plan will be on the top.
Clear browser cache
(03.02.2023, 09:15)Daniel Wrote: One should be on layout and second on plan. The one on plan will be on the top.
Clear browser cache
by a layout you mean one of them should be made with the background already ?
Page 57
https://openrb.com/wp-content/uploads/20...3.2022.pdf
(03.02.2023, 09:24)Daniel Wrote: Page 57
Yes, it worked now and it was not the case with SW 20211215 (attached)
It will take more time now...
This hasn't changed for 10 years Smile
(03.02.2023, 09:39)Daniel Wrote: This hasn't changed for 10 years Smile
That's really weird  Huh
Clear browser cache
Thanks for the support ️
