HDL Buspro gateway integration with LM5
Dear Admin,
I found the gateway example for HDL Buspro product.https://openrb.com/example-hdl-integrati...rough-lm2/
I am not sure if LM5 can use this script as a tool to connect the HDL product "HDL-MHRCU.433".
Or some modifications need to be taken for this script?
And I can't find out related "Add the following script in Scripting -> Tools -> User function library"
More details about this product" HDL-MHRCU.433 ", please refer to the PDF attachment .
.pdf   HDL Buspro_Home Control Unit.pdf (Size: 589.44 KB / Downloads: 29)
Thank you very much for your time.
Best regards.
It should work unless HDL changed their protocol.
The script is slightly outdated, this line:
require('crc16')
Should be replaced with this:
crc16 = require('encdec').crc16
(14.02.2023, 07:53)admin Wrote: It should work unless HDL changed their protocol.
require('crc16')
Dear Admin, Thanks a lot. I will test it later.
Dear Admin,
I have tested the script for several times, but still no response from HDL side.
I am not sure if I put the script at the right way and right place---"Add the following script in Scripting -> Tools -> User function library", more details, please refer to picture.
I use HDL buspro tool to search or scan devices, but I can't find the Device ID for LM5 is 254. ID 254 is default for LM5?
Thanks!
Richard
LM won't be visible as a device on the HDL network. The example only allows to control HDL channels from scripts.
Dear Admin,
I tried again to use LM5 to send switch on/off signal to HDL IP unit (IP Add.=192.168.1.37, Subnet=1 Device=0).
The HDL device (Subnet=1 Device=61) is 8 channels switch module, which also connects to HDL IP unit.
The script user.hdl is copied from example(openrb.com) , and  "require('crc16')" is replaced by "crc16 = require('encdec').crc16"
The event-based script also set up according to example(openrb.com) .
14/0/220 is created to test the script.
When I turn on 14/0/220, the following error happens
User library hdl:30: bad argument #1 to 'pdecode' (expected 1 argument)
stack traceback:
[C]: in function 'pdecode'
User library hdl:30: in function 'init'
User library hdl:99: in function 'encode'
User library hdl:137: in function 'chanreg'
I don't know what is the root cause and how to slove this problemHuh.
Try this updated library. Let us know if it works so we can update the example on our website.
local socket = require('socket') local crc16 = require('encdec').crc16 local ifinfo = require('ifinfo') HDL = {   -- destination ip   dstip = '192.168.0.2',   -- packet constant data   magic = 'HDLMIRACLE',   lcode = string.char(0xAA, 0xAA),   -- source device settings   srcsubnet = 1,   srcdevice = 254,   devicetype = 0xFFFE,   -- command types   cmd = {     chanreg = 0x0031, -- single channel regulate     chanregreply = 0x0032, -- single channel regulate answerback     chanstat = 0x0033, -- read status of single channel targets     chanstatreply = 0x0034, -- single channel targets status answerback   } } HDL.init = function()   local info, chunk, chunks   info = ifinfo()   if not info or not info.eth0 then     error('cannot get interface info')   end   -- ip header   HDL.iphdr = ''   -- broadcast address   HDL.bcast = info.eth0.bcast   -- split ip address into chunks   chunks = info.eth0.inetaddr:split('.')   -- add ip address chunks   for i = 1, 4 do     chunk = tonumber(chunks[ i ])     HDL.iphdr = HDL.iphdr .. string.char(chunk)   end end HDL.decode = function(packet)   local len, data, src, crc   -- primary header   if packet:sub(5, 14) ~= HDL.magic then     return nil, 'magic'   end   -- leading code   if packet:sub(15, 16) ~= HDL.lcode then     return nil, 'lcode'   end   -- get data length and check against   len = packet:byte(17)   if len and len + 16 ~= packet:len() then     return nil, 'len'   end   -- get packet data and check crc   data = packet:sub(17, len + 14)   crc = packet:byte(len + 15) * 0x100 + packet:byte(len + 16)   if crc16(data) ~= crc then     return nil, 'crc'   end   -- return parsed packet   return {     srcip = string.format('%d.%d.%d.%d', packet:byte(1, 4)),     srcsubnet = packet:byte(18),     srcdevice = packet:byte(19),     devicetype = (packet:byte(20) * 0x100 + packet:byte(21)),     opcode = (packet:byte(22) * 0x100 + packet:byte(23)),     dstsubnet = packet:byte(24),     dstdevice = packet:byte(25),     additional = packet:sub(26, len + 14)   } end HDL.word = function(v)   return string.char(bit.band(bit.rshift(v, 8), 0xFF), bit.band(v, 0xFF)) end HDL.encode = function(cmd, dstsubnet, dstdevice, extra)   local packet, len, crc, data   -- perform init if required   if not HDL.iphdr then     HDL.init()   end   -- start packet: ip, magic and leading code   packet = { HDL.iphdr, HDL.magic, HDL.lcode }   -- base data   data = string.char(HDL.srcsubnet, HDL.srcdevice) ..     HDL.word(HDL.devicetype) ..     HDL.word(cmd) ..     string.char(dstsubnet, dstdevice)   -- add extra data parameters   if type(extra) == 'string' then     data = data .. extra   end   -- calculate length and crc   len = string.char(data:len() + 3)   crc = crc16(len .. data)   table.insert(packet, len)   table.insert(packet, data)   table.insert(packet, HDL.word(crc))   return table.concat(packet) end HDL.send = function(packet)   local client = socket.udp()   client:sendto(packet, HDL.dstip, 6000) end HDL.chanreg = function(dstsubnet, dstdevice, chan, value, delay)   local extra, packet   delay = delay or 0   if type(value) == 'boolean' then     value = value and 100 or 0   end   extra = string.char(chan, value) .. HDL.word(delay)   packet = HDL.encode(HDL.cmd.chanreg, dstsubnet, dstdevice, extra)   HDL.send(packet) end
Dear Admin,
Excellent!!!
Problem is solved with this script!
Thanks a lot!
Richard
Hi I have used the script, it is working fine. How will I get the status (feedack) from buspro (HDL) relay to Logic Machine 5 when I trigger the relay from the HDL Keypad.
Use this script (resident, sleep time = 0) to catch HDL messages. You need to configure your gateway to forward messages to LM. You will have to check opcode and additional field values to determine the HDL packet contents.
if not sock then   require('user.hdl')   sock = socket.udp()   sock:settimeout(60)   sock:setsockname('*', 6000)   HDL.init() end data = sock:receive() if data then   packet, err = HDL.decode(data)   if packet then     packet.additional = lmcore.strtohex(packet.additional)     log('HDL packet', packet)   else     log('HDL error', err)   end end
Hi I used the above mentioned resident script and I am getting logs when I am Operating the relay channel. But how do I use these logs to update the status group address.
STATUS copy 22.06.2025 15:20:12
* arg: 1
* string: HDL packet
* arg: 2
* table:
["additional"]
* string: 01F864040F
["dstdevice"]
* number: 255
["srcsubnet"]
* number: 1
["devicetype"]
* number: 487
["srcdevice"]
* number: 6
["dstsubnet"]
* number: 255
["opcode"]
* number: 50
["srcip"]
* string: 192.168.0.25
STATUS copy 22.06.2025 15:20:15
* arg: 1
* arg: 2
* table:
["additional"]
* string: 01F800040E
["dstdevice"]
* number: 255
["srcsubnet"]
* number: 1
["devicetype"]
* number: 487
["srcdevice"]
* number: 6
["dstsubnet"]
* number: 255
["opcode"]
* number: 50
["srcip"]
Try this:
if not sock then   require('user.hdl')   sock = socket.udp()   sock:settimeout(60)   sock:setsockname('*', 6000)   HDL.init() end data = sock:receive() if data then   packet, err = HDL.decode(data)   if packet then     if packet.opcode == HDL.cmd.chanregreply then       channel, _, value = packet.additional:byte(1, 3)              if channel == 1 then         grp.checkupdate('1/1/1', value)       elseif chanel == 2 then         grp.checkupdate('1/1/2', value)       elseif chanel == 3 then         grp.checkupdate('1/1/3', value)       elseif chanel == 4 then         grp.checkupdate('1/1/4', value)       end             end     -- packet.additional = lmcore.strtohex(packet.additional)     -- log('HDL packet', packet)   else     log('HDL error', err)   end end
If you have multiple HDL relay devices then you need to check packet.srcdevice value to determine the status group address.
