Backup file is invalid
Hello guys,
is it normal to have a backup file working last week and then suddenly being 'invalid' two days after ?
how can I know if the problem is coming from the file or the controller ?
Thanks in advance
Are you using the same device or different? Backup made on a newer firmware might not work on older firmware.
(27.03.2023, 10:24)admin Wrote: Are you using the same device or different? Backup made on a newer firmware might not work on older firmware.
yes same device, same firmware
Can you send your backup via PM?
(27.03.2023, 11:58)admin Wrote: Can you send your backup via PM?
Thanks it worked, i think it was facing some problem while uploading the backup file
i changed my connection and then it worked
thanks for the help!
