Hi. My Logs has just started to fill up with events from script "Broker.BrokerClient" with different messages which I do not understand and I am not quite sure where to start to get rid of the issue with flooded loggs. I tried to disable most scrpipts with no luck - so based on a couple of searches I suspect this to be modbus related. There are 1 modbus RTU device (Ventilation system - Seems to work like it should) and there are 9 TCP modbus connections (Scheneider Power Tag modules).
Any ideas where the problem lays based on the log below?
Logg
![[Image: 202307_wiserLogs.png]](http://www.sterk.no/images/202307_wiserLogs.png)
Error Logg (PNG)
* arg: 1
* string: [DEBUG]
* arg: 2
* string:
BROKER_CLIENT:
* arg: 3
* string: DEBUG 5310:
* arg: 4
* string:
RPC_SOCKET_CLIENT:
* arg: 5
* string: DEBUG 3924:
* arg: 6
* string: Step RPC server on_message call
Wiser for KNXLogoutStart pageLanguage:
English
Version: 2.8.3
CPU/IO: 0.09 0.16 0.19, Memory: 17% Disk: 27%, KNX/TP: OK
* arg: 1
* string: [DEBUG]
* arg: 2
* string:
BROKER_CLIENT:
* arg: 3
* string: DEBUG 5318:
* arg: 4
* string: RpcClient:on_message:
* arg: 5
* table:
["headers"]
* table:
["timestamp"]
* number: 1690395032
["user-id"]
* string: APIT3
["content-type"]
* string: application/json
["command"]
* string: RESPONSE_HEARTBEAT
Logg
Error Logg (PNG)
* arg: 1
* string: [DEBUG]
* arg: 2
* string:
BROKER_CLIENT:
* arg: 3
* arg: 4
* string:
RPC_SOCKET_CLIENT:
* arg: 5
* arg: 6
English
Version: 2.8.3
* arg: 1
* string: [DEBUG]
* arg: 2
* string:
BROKER_CLIENT:
* arg: 3
* arg: 4
* arg: 5
* table:
["headers"]
* table:
["timestamp"]
["user-id"]
* string: APIT3
["content-type"]
["command"]
