26.09.2023, 17:52
		hi, i have around 50 lights that i want to control with a widget in mosaic
I created a group object in ETS with the on/off switch object and another one for the on/off status and set the the widget to use those
If I set up a widget to control some of these lights it works (around 5-10 lights at time)
If I try to set up a widget which should turn on and of all the lights it doesn't work properly: if I click the widget the lights do turn on but the on/off status is not showing up properly. If i press the button quickly they do turn off
There are some dali ballasts (MDT dali module) and some other lights are controlled by an actuator (AH9F16-Q)
