Mosaic: No automatically login if in intranet-mode
Hi, i'm posting this due i've got some trouble with Mosaic today.
I've done these things:
- configured Mosaic with my items/widgets
- connected LM to cloud
- created a new mail/password access
- created a new connection string
- pasted the connection string under LM-cloud field
- installed the Logicmachine app in the smartphone
- configured remote access
- finded and configured (with password) my local LM5 in the same network
Now, if i'm disconnected from the local network and navigate with 3g/4g or another wifi network, i can easily access my lm5-Mosaic easily and instantly.
If im connected to the intranet, in the same network of LM, i can't access the machine locally nor remote. I've tryed changing the redirect page to see if something changes but i've not solved anything.
Can you try to help me out?
Have a great day
Can you access LM home page while locally?
That's my schema:
LM5 - IP 192.168.10.10 -- connected to router 1 - 4g/LTE Router
Step 1: Remote method: I connect my tablet to an external wi-fi on my, for example, router 2 with adsl internet. I start the LogicMachine app on Android, click the cloud icon, click on the LM i've configured and i enter Mosaic.
Step 2: Now i connect the tablet directly to router 1 - with his own wi-fi. I can surf internet while connected to this wi-fi. Now, i start the logicmachine app on android, and i'm going to the "search" button, and i scan the network and i find my Web Server on LM5-Test. Click the + button:
- IP: 192.168.10.10
- user: admin
- psw: myadminpsw
- "Do you want auto load this device..." --> YES
Step 3: close the app and restart it
Now, while im connected to the LM5-wifi router 1, whenever the app load itself i cant access remotely or locally my LM. The app starts and goes stuck in a white screen like it hasn't found anything.
If i connect to router 2 i can access remotely my LM using cloud.
When you are on router 1 on wi-fi can you connect to LM via browser on the tablet?
(11.10.2023, 14:05)Daniel Wrote: When you are on router 1 on wi-fi can you connect to LM via browser on the tablet?
Yes, i can log on, and work with my objects
Which Android version is it?
Do you have password for apps enabled? User access settings
(11.10.2023, 14:15)Daniel Wrote: Which Android version is it?
Android Version: 12 - normal, not GO Android
(11.10.2023, 14:15)Daniel Wrote: Do you have password for apps enabled? User access settings
Yes, i've tryed to create another user rather than admin, and provide only mosaic access to it. But i have not noticed any changes.
Update 16:45: Right now, i've tryed to redirect the autoload page to Mainpage and i can connect to it. If i run Mosaic from here, after some seconds it starts but seems so slowly.
Update 16:52: After 4 minutes stucking on a white page, Mosaic finally starts.
After this, i'm restarting it a few times and seems to speed up.
I absolutely don't know what changed. I've sync with cloud only.
Send me your backup to PM, will check why the load is so long. Use wetransfer.com or similar.
(11.10.2023, 15:00)Daniel Wrote: Send me your backup to PM, will check why the load is so long. Use wetransfer.com or similar.
Done
