Hi @all,
I want to connect a Siemens 7KT PAC1600 Energy Meter to the universal Modbus Slave running on LM.
from reading test the result is corect : see the attached immage.
Please see also the atache manual with the modbuss adress (this are working for nodered)
I need you help for create a .json file that map the Read Input Registers [4] , only an example, the rest il will do from the manual
7KT_Multimetro_it-IT (1).pdf (Size: 3.87 MB / Downloads: 10)
Many thanks for your help!
Best regards
Costantino
7KT_Multimetro_it-IT (1).pdf (Size: 3.87 MB / Downloads: 10)Many thanks for your help!
Best regards
Costantino
