Circular-slider adding symbols
Hi guys, I know that I annoying you with my strange questions but I need your help! Wink
I have a circular slider that controls a 1 byte integer that that have a limited range +-3, now my problem is that I would like to display the plus symbol (+) before the number when it is greater than zero, like it happened with the minus symbol (-) when the number is lower than zero.
I tryed to write some javascript code but nothing worked.. Can someone help me?
I almost solved it with this code:
$('.example .circularslider-max').on("vclick", function() {    setTimeout(function() {      var val = $('.example .circularslider-value').text();      if (val == "1" || val == "2" || val == "3")      {        val = "+" + val;        $('.example .circularslider-value').text(val);      }    }, 120);  });
But it doesn't work really well because sometimes the other script overwritten the value..
Try this:
$(function(){   var el = $('.example > div').data('circularslider').$value       , fn = el.text;      el.text = function(v) {     if (typeof v != 'undefined') {       if (parseInt(v, 10) > 0) {         v = '+' + v;       }       return fn.call(el, v);     }     else {       return fn.call(el);     }   }   el.text(el.text()); });
Thank you admin! It works perfectly! Big Grin
Is there a way to do the same thing with the +/- spinner?
Probably not, because spinner uses numeric input field which will not accept this format.
Even if I force the spinner to be type = "text", with this code?
$('.example .spinner-value').attr('type', 'text');
I would like to put a zero (0) before the value when it is between 0 and 10
You can try but this might break direct input. You will have to over-ride val function instead of text.
