Threads: 31
Can you login with the same user here?
https://remote.logicmachine.net/user
Threads: 18
Yeah, that's no problem. The connection is made aswell. I can control my groups via the Mosaic app
Threads: 31
Did you sync LM cloud app after configuring google home app?
Threads: 18
Yes. Just did again.
This time I did have the option to log-in via FB og Google or Username & Password. Tried to log in via Username and Password, but I get the same message...
Threads: 31
I just tried it all over again and work fine for me. If you are using her
https://remote.logicmachine.net/user external google account then while linking accounts in via google home app you also must select google and fallow the google login procedure. If you registered in our cloud then you use email and password.
Threads: 18
Okay... I still can't do it.
Just to be sure; is there anything I should have in the LogicMachine App for Android? I've logged in, and logged in for the settings' "remote", but nothing for the "Home" part of setting.
Threads: 31
LM android app has nothing to do with Google home.
Threads: 18
But this is not an issue you've heard of mor encountered before?
And you'd say the issue is at Google, and not the LogicMachine?
Threads: 31
I don't know what is the issue because I just tried the whole procedure and all worked just fine, you probably missed some step.
Go to LM Cloud app and show what the logs says.
Threads: 31
If you didn't configured any devices in Google Home app then the message displayed above is 100% correct.
Threads: 31
Yes, voice config app and google home app are totally different things not related to each other.
