Threads: 7
I want to send command for sauna control over RS485
Comand list
How need to look my command in LM?
require (
'serial' )
port =
serial.open (
'/dev/RS485-1' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
port :
flush ()
log =
port :
write (
info )
port :
close ()
Threads: 43
port :
write (
'set sauna on\r' )
port :
write (
'set sauna val 70\r' )
Threads: 7
This is correct that I done in resident for reading:
require (
'serial' )
port =
serial.open (
'/dev/RS485-1' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
port :
flush ()
grp.write (
'32/2/2' ,
port :
write ((
'get sauna val\r' ),
'uint16' ))
port :
close ()
Threads: 43
If you want to query status periodically then things get more complicated. You need to have a single resident script which will handle both reading and writing because you cannot have multiple scripts accessing serial port at the same time.
You also need to parse the response because the reply will contain some additional characters.
This should log raw response of temperature value.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
function readack ()
local line = {}
while true do
local char ,
err =
port :
read (
1 ,
5 )
if char ==
nil then
return nil ,
err
elseif char ==
';' then
break
line [ #
line +
1 ] =
char
return table.concat (
line )
port :
write (
'get sauna val\r' )
res ,
err =
readack ()
log (
res ,
err )
Threads: 7
Ok connection is working maybe you know why I get not correct value?
Threads: 7
Evrithing is good its working code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
require (
'serial' )
port =
serial.open (
'/dev/RS485-1' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
port :
flush ()
function readack ()
local line = {}
while true do
local char ,
err =
port :
read (
1 ,
5 )
if char ==
nil then
return nil ,
err
elseif char ==
';' then
break
line [ #
line +
1 ] =
char
line )
port :
write (
'get sauna\r' )
res ,
err =
readack ()
log (
res ,
err )
port :
close ()
Threads: 17
Hi.
I get response timeout when running this script in wiser knx. is there any difference for RS-485 port?
I´ve tested this script over here and also with
This:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
require (
'serial' )
local port ,
errorMsg =
serial.open (
'/dev/RS485' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
if not port then
log (
"Kunde inte öppna porten: " .. (
errorMsg or "Okänt fel" ))
return
port :
flush ()
local function readack ()
local line = {}
while true do
local char ,
err =
port :
read (
1 ,
5 )
if char ==
nil then
return nil ,
err
elseif char ==
';' then
break
table.insert (
line ,
char )
line )
local bastuState =
grp.getvalue (
'37/1/1' )
if bastuState then
port :
write (
'set sauna on\r' )
port :
write (
'set sauna off\r' )
local temperature =
grp.getvalue (
'37/1/3' )
port :
write (
'set sauna val ' ..
temperature ..
'\r' )
port :
write (
'get sauna val\r' )
local res ,
err =
readack ()
if res then
log (
"Sauna värde: " ..
res )
grp.checkwrite (
'37/1/0' ,
res )
grp.checkwrite (
'37/1/4' ,
res )
log (
"Fel vid läsning av bastu värde: " .. (
err or "Okänt fel" ))
port :
close ()
Anone who can see something wrong in this script?
Threads: 43
Script should call readack() after every command (both set and get). But this won't cause last readack() to return timeout. Something is wrong on the communication level. Try swapping A/B and see if GND is connected.
Threads: 17
(06.10.2023, 12:43) admin Wrote: Script should call readack() after every command (both set and get). But this won't cause last readack() to return timeout. Something is wrong on the communication level. Try swapping A/B and see if GND is connected.
Thanks this helped.
Now runs thhis script and its working.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
require (
'serial' )
local port ,
errorMsg =
serial.open (
'/dev/RS485' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
if not port then
log (
return
port :
flush ()
local line = {}
local crlf_received =
false
while not crlf_received do
local char ,
err =
port :
read (
1 ,
5 )
if char ==
nil then
return nil ,
err
elseif char ==
'\r' then
elseif char ==
'\n' then
crlf_received =
true
table.insert (
line ,
char )
local response =
table.concat (
line )
if string.sub (
response , -
1 ) ==
';' then
response =
string.sub (
response ,
1 , -
2 )
return response
local function sendAndRead (
command )
log (
"Skickat kommando: " ..
command )
port :
write (
command ..
'\r\n' )
return readack ()
local bastuState =
grp.getvalue (
'37/1/1' )
sendAndRead (
bastuState and 'set sauna on' or 'set sauna off' )
local temperature =
grp.getvalue (
'37/1/3' )
local tempResponse =
sendAndRead (
'set sauna val ' ..
temperature )
if tempResponse then
log (
"Svar på temperaturinställning: " ..
tempResponse )
grp.checkwrite (
'37/1/4' ,
temperature )
local currentStatus =
sendAndRead (
'get sauna' )
if currentStatus then
local status =
string.match (
currentStatus ,
"SAUNA%s(%w+)" )
if status then
log (
"Bastuns nuvarande status: " ..
status )
local knxStatus = (
status ==
"on" )
and 1 or 0
grp.checkwrite (
'37/1/0' ,
knxStatus )
log (
"Kunde inte tolka bastuns nuvarande status från svaret: " ..
currentStatus )
port :
close ()
Build on more functions for the sauna with following script and with the new one it does not work, is there any solution you can see?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110
require (
'serial' )
local port ,
errorMsg =
serial.open (
'/dev/RS485' , {
baudrate =
57600 ,
parity =
'none' ,
duplex =
'half' ,
databits =
8 ,
stopbits =
1 })
if not port then
log (
return
port :
flush ()
local line = {}
false
local char ,
err =
port :
read (
1 ,
5 )
if char ==
nil and err then
log (
"Läsfel: " ..
err )
return nil ,
err
elseif char ==
'\r' or char ==
'\n' then
if char ==
'\n' then
crlf_received =
true
elseif char then
table.insert (
line ,
char )
local response =
table.concat (
line )
log (
"Mottaget svar: " ..
response )
if string.sub (
response , -
1 ) ==
';' then
response =
string.sub (
response ,
1 , -
2 )
return response
command )
log (
command )
port :
write (
command ..
'\r\n' )
return readack ()
local function handleTimerStatus ()
local timerStatus =
grp.getvalue (
'37/1/5' )
local response =
sendAndRead (
timerStatus and 'set timer on' or 'set timer off' )
if response then
local status =
string.match (
response ,
"timer%s(%w+);" )
grp.checkwrite (
'37/1/6' ,
status ==
"on" and 1 or 0 )
local function setAndQueryTimerTime ()
local timerTime =
grp.getvalue (
'37/1/7' )
sendAndRead (
'set timer val ' ..
timerTime )
local timerTimeResponse =
sendAndRead (
'get timer val' )
if timerTimeResponse then
local timeValue =
string.match (
timerTimeResponse ,
"timer%s(%d+);" )
grp.checkwrite (
'37/1/8' ,
tonumber (
timeValue ))
local function handleUserProgram ()
local userProgram =
grp.getvalue (
'37/1/9' )
local response =
sendAndRead (
userProgram and 'set user-prog on' or 'set user-prog off' )
if response then
local status =
string.match (
response ,
"user%-prog%s(%w+);" )
grp.checkwrite (
'37/1/10' ,
status ==
"on" and 1 or 0 )
local programNumber =
grp.getvalue (
'37/1/11' )
local programResponse =
sendAndRead (
'set user-prog val ' ..
programNumber )
if programResponse then
local currentProgram =
string.match (
programResponse ,
"user%-prog%s(%d+);" )
grp.checkwrite (
'37/1/12' ,
tonumber (
currentProgram ))
local function getControlUnitStatus ()
local response =
sendAndRead (
'get status' )
if response then
local status =
string.match (
response ,
"STATUS%s(%w+)" )
if status then
grp.checkwrite (
'37/1/20' ,
"Bastu " ..
status )
log (
"Kunde inte tolka Control Unit status från svaret: " ..
response )
port :
close ()
Threads: 43
Do you get anything in logs? Any response from the readack() function?
Threads: 17
Gets this in my log, sorry for the swedish text in log
Bastu Status REV 13.12.2023 09:25:16
* string: Skickat kommando: set timer val 240
* string: Mottaget svar: TIMER 240min ;
* string: Skickat kommando: get timer val
* string: Skickat kommando: set user-prog val 1
* string: Mottaget svar: USER-PROG 1 ;
* string: Skickat kommando: get status
* string: Mottaget svar: STATUS OK;
The sauna activates with one relay but directly shuts off.
Threads: 43
The response is uppercase so your regexp won't work because it's lowercase. Use 'USER%-PROG%s+(%d+)' for user program detection and 'TIMER%s+(%w+)' for timer. Modify other regexps in a similar way.
Threads: 17
Okey, now gets this in Log.
Bastu Status REV 13.12.2023 09:52:22
* string: Mottaget svar: �TIMER 240min ;
* string: Skickat kommando: set user-prog off
* string: Mottaget svar: USER-PROG off;
Threads: 43
Post you current script. What exactly is not working after the regexp changes?
