Threads: 21
(17.05.2024, 07:09)phongvucba Wrote: (16.05.2024, 09:33)Daniel Wrote: (16.05.2024, 09:19)phongvucba Wrote: hi, pro !
I used Android !
Which Android version, we tested from 10 to 14
I use samsung S22ultra, android version 14
Can you record a video of what you see on mobile? I have S24 with Andrid 14. Tested also on S20 ultra and S21.
Threads: 21
New app with multi LM feature added is on App Store and Play Store.
Instructions:
1. Make sure that LogicMachine has firmware 2024 or newer.
2. Open app while on the same network as LogicMachine. If there is only one LM then app will automatically connect and ask for user and password, this must be added once. If there is more then one LM on the network app will allow to select LM to connect too.
3. To add more LMs press and hold the app icon on mobile and select Add LM.
4. Co connect to cloud turn off Wi-fi or connect from a network where LogicMachine is not present.
5. To remove already saved credentials, select Clear cache. Clear config will remove all added LMs. To remove single LM select Remove LM and then select LM which should be removed.
Threads: 21
Record screen recording of what you are doing.
Threads: 21
The credentials are saved in cache on your mobile. The process how cache is saved is managed by your device and it is not clearly define how often/fast it saves. If you login and then kill the app, the cache might not be saved and then you will be asked again. Once it work it should work.
Threads: 53
14.06.2024, 15:45
(This post was last modified: 14.06.2024, 15:46 by CristianAgata.)
Hi @Daniel,
I can't understand when I install more then one LMs on LM HOME. How can I switch to one from other when I'm connected in local mode?
Best Cristian
Threads: 21
You just close the app and open again, it will let you select then.
Threads: 21
Once you add second LM by selecting Add LM then when both LMs are on the network app will show selection window. If only one of the two is on the network then it will open the LM which as found. If none were found cloud will be opened.
