Zigbee gateway integration
Basic lamps (on/off + level) will work without a profile. RGB/TC lamps require a profile to be added to the app. It's a trivial task and can be done quickly. We just need to know which manufacturer/model name is reported from the lamp.
Hi at all,
I have a client with several thermostatic valves Ezviz.
This is the information:
Is it possible add in future upgrades?
Manufacturer: EZVIZ
Model: CS-T55-R100-G
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- PowerCfg (1)
- PollCtrl (32)
- 1796
- SsIasZone (1280)
- OnOff (6)
- HvacThermostat (513)
- MsTemperatureMeasurement (1026)
- 65216
- 65024
Output clusters
- Ota (25)
- 1796
Reported attributes
- calclevel: 0
- occupiedheatingsetpoint: 50.00
- onoff: false
- systemmode: 16
- temperature: 20.10
It can be added but it will require some additional testing. Some features might not work - it reports system mode 16 but ZigBee standard only defines modes from 0 to 9.
For a project i need this Product MHCOZY Zigbee température
I see the ON/OFF object but i don't see the temperature
Manufacturer: _TZ3218_7fiyo3kv
Model: TS000F
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- 57345
- 57344
- 61184
Output clusters
- Time (10)
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- onoff: true
- prevlevel: 254
@hocine, this device uses a non-standard cluster for temperature reporting which we don't support. To work with our gateway it must have MsTemperatureMeasurement (1026) cluster.
Im using eWeLink - MS01 PIR sensor with zigbee, is ther any way to alter the timeout/on duration of the sensor from LM?
Try running this script to check if the delay can be read from the sensor. Change the addr variable to the sensor address and wake up the sensor manually right before running the script.
zb = require('applibs.zigbee')
addr = '0123456789abcdef'
cluster = 0x0406 -- MsOccupancySensing
attrs = { 'PirOToUDelay' }
res, err = zb.cmdsync('getnamedattributes', addr, cluster, attrs)
log(res, err)
(16.09.2024, 07:43)admin Wrote: Try running this script to check if the delay can be read from the sensor. Change the addr variable to the sensor address and wake up the sensor manually right before running the script.
log(res, err)
zi
i got the following in the logs
* arg: 1
  * nil
* arg: 2
  * string: no response
also here is the device info, in case it maked a difference?
Manufacturer: eWeLink
Model: MS01
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- SsIasZone (1280)
- PowerCfg (1)
Output clusters
- Identify (3)
Reported attributes
- detection: false
You need to wake up the device just before running the script. Usually this can be done by pressing the programming/reset button on the device itself. If you are not quick enough then the device will go into sleep mode again and won't communicate.
Is it possible to add support for this device?
This is a HAN/m-bus interface over Zigbee. Very common in Norway.
Develco EMIZB-132 control via MQTT | Zigbee2MQTT
Manufacturer: Develco Products A/S
Model: EMIZB-132
Endpoint 1
Profile: 49353
Input clusters
- Identify (3)
- Scenes (5)
- OnOff (6)
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- PollCtrl (32)
- SeMetering (1794)
- 1796
- HaMeterIdentification (2817)
- HaElectricalMeasurement (2820)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
Thanks in advance! Smile
Please let me know if you need any more information.
Best regards
Valter Emil
Hello, I am looking for a thermostat with an external sensor that is supported by the controller.
Can you give me a reference?
(18.09.2024, 07:40)hocine Wrote: Hello, I am looking for a thermostat with an external sensor that is supported by the controller.
We didn't test it but the BOSCH - Radiator thermostat II supports external temperature.  SE has ITRV which we support but you better ask them as they have two version which looks identical.
i search a product like that.
https://moeshouse.com/products/zigbee-pr...eq=uniform
Manufacturer: _TZE204_aoclfnxz
Model: TS0601
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Groups (4)
- Scenes (5)
- 61184
- Basic (0)
Output clusters
- Ota (25)
- Time (10)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
@valteremil93, it will be quite hard to add support for this device without being able to test it locally.
@hocine, this device won't work because it uses a non-standard implementation.
(16.09.2024, 11:50)admin Wrote: You need to wake up the device just before running the script. Usually this can be done by pressing the programming/reset button on the device itself. If you are not quick enough then the device will go into sleep mode again and won't communicate.
I wasn't able to make this happen with any success.
Maybe a problem with my sensor, or perhaps I’m doing it wrong.
I have tried pressing the button the side then running the script as resident, get nil result each time.
Any other things I can try?
Br
I have wiser for knx with LSS100400.
I have a Sonoff water valve. It is working correctly (on/off) through the app, but not from the group address, it does not turn on, but I can turn it off. I suppose it is because it is a battery powered device. Can this be solved?
Manufacturer: SONOFF
Model: SWV
Firmware version: 1.0.2
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- OnOff (6)
- PollCtrl (32)
- MsFlowMeasurement (1028)
- HaDiagnostic (2821)
- 64599
- 64529
Output clusters
- Time (10)
- Ota (25)
Reported attributes
- calclevel: 0
- onoff: false
- prevlevel: 254
@Tifon, since the device advertises itself as sleepy (battery + no receive when idle) the mapped object value is not sent until the device wakes up and sends something first. The only solution is to add a profile which overrides the sleepy mode.
(Yesterday, 12:50)admin Wrote: @Tifon, since the device advertises itself as sleepy (battery + no receive when idle) the mapped object value is not sent until the device wakes up and sends something first. The only solution is to add a profile which overrides the sleepy mode.
Thank you, how can i do that?
