CAN and KNX communication
管理员您好,我无法拉动两个电箱之间的电缆,这时我想到了CANx-LORA,但是不确定第一个电箱的CAN执行器是否可以发送命令来控制第二个电箱的KNX设备,传输设备是LM5p2-KC,CAN-R4-LoRA*2
I can't pull the cable between the two electrical boxes. At this time, I thought of CANx-LORA, but I'm not sure whether the CAN actuator of the first electrical box can send commands to control the KNX device of the second electrical box. The transmission device is LM5p2-KC, CAN-R4-LoRA*2
Please post in English next time.
This is only possible with 2 LMs. The whole communication chain will look like this:
KNX¹ - LM¹ - CANx¹ - LORA - CANx² - LM² - KNX²
(30.08.2024, 06:37)管理 Wrote: 下次请用英文发布。
这仅适用于 2 个 LM。整个通信链将如下所示:
谢谢,因为我现在在中国,无法观看视频资料,你们有没有关于配置步骤的手册可以参考呢?
(30.08.2024, 06:37)admin Wrote: Please post in English next time.
Thanks, since I'm in China right now and can't watch the video, do you have a manual on the configuration steps that I can refer to?
In the CANx app create the required objects and enable "Export to LM object" to exchange values between CANx and KNX.
Both CANx devices must have the same LoRa settings - frequency, bandwidth, spreading factor and encryption key.
