LM Home app (Andrоid/iOS starter)
#81
(31.01.2024, 08:44)Daniel Wrote: For multi LM the existing starter app can be used, we are not removing it from the store.
I've noticed that using older starter app, IOS and the latest firmware, user and password are not saved...
When using older firmwares it works
Did you update starter app to the latest version? We had to make workaround for it.
(18.09.2024, 15:30)Daniel Wrote: Did you update starter app to the latest version? We had to make workaround for it.
I've updated to the lastest version and it works! Thanks!
Hi, can you please provide .apk file again
? Will it work on Oreo 8.1 android (specific web display).
LM Home app works from Android 10, I can share the old LogicMachine app which should work on it.
Or you can just use a shortcut, with new authentication it also should work well.
Please provide old app, will try to use it
Alex
https://we.tl/t-wX9eXfNrBO
This function is awesome, when will this feature be completed on IOS
Jus search for LM Home on the app store
