MQTT Client app
MQTT client app is now published in LM app store.
The app will run on all controllers, none LM too.
The first step is to establish communication with the Broker. Under the gear icon the MQTT configuration can be set. After saving the dot in the top right corner will highlight if communication was established or not. Green means connected, red the opposite.
There are also connection logs and help with a link to this thread.
Add topic
Common options
  • Direction - defines the communication direction, it can be in Both, In (From MQTT) and Out (To MQTT)
  • Topic name is what the name defines.
  • Mapped object is the object from which the value will be read/written. This option is not needed if Direction is In (From MQTT) as the payload can contain several values.
Out (to MQTT) options
  • Publish QoS - Quality of Service level when publishing data to MQTT. Use QoS 0 when using a local broker on the same LM. More info here.
  • Retain message tells broker to keep the last value. Any new client subscribing to the topic will receive the last value, otherwise will need to wait for a change. More info here.
  • Publish current value when connected to broker - when enabled the current object value is published when a connection to the broker is established.
In (from MQTT) options
  • Publish QoS - Quality of Service level when subscribing to data to MQTT. Use QoS 0 when using a local broker on the same LM.
  • Send delta - minimum value difference to trigger group
  • Throttle time (seconds) - set a minimum time between MQTT messages. A timer is started when a message is received. Any new messages are ignored until the time expires.
  • Write to bus - defines where to write values to KNX/TP or not.
  • JSON value path - extracts value from a JSON payload, see example below.
Boolean to string conversion (applies only to 1-bit objects)
  • Converts 1-bit object value to a string when publishing to MQTT and a string payload to 1-bit when a message is received from MQTT. Values received from MQTT that do not match either ON or OFF string are ignored.
JSON value path example
MQTT payload is the following JSON, battery level % needs to be obtained.
{   "id": "0",   "battery": {     "V": 2.99,     "percent": 93   } }
The root object contains an object named battery which has a percent value. The resulting JSON value path is battery.percent
Arrays are also supported with indexes starting from 1 because the JSON payload is converted to Lua.
No write is performed if the payload is not a valid JSON or the path cannot be found.
Scripts
In MQTT there is no definition of how the data is structured. To overcome this problem each topic has a script attached to convert the data to a correct format if needed. Script example and more info on how the conversion works is defined in this guide. Script errors can be viewed in the LM Error log. Each script has its own global environment, meaning that global variable values are kept between each execution but these variables are not shared between scripts.
Please report any issues or questions here.
Very promising library, hides complexities of integration while allowing to focus on actual value conversion routines. I found one issue and one suggestion:
1) ISSUE: lack of scope isolation between scripts. If code will be reused by copy&paste, any issue where user failed to use "local" definition (variable or function) will cause to overwrite values between scripts, which can cause hard to debug issues.
However, if fixed, i would like you to retain global scope within script, that is any defined global variable keeps its value between script executions. If not fixed, this should be explicitly mentioned in the documentation, and also suggestion that follows my post should be implemented Wink .
One of the examples where it's beneficial having global variable retain its value is having Throttle function implementation like this:
local data = json.pdecode(payload) if type(data) == 'table' then   val = data.illuminance     -- global variable here that should retain its value between executions   last_update = last_update == nil and 0 or last_update   ---   local now = os.time()   if((now - last_update) < 60) then     return nil   else     last_update = now     return val   end end
2) SUGGESTION: like in example above, i would like to have Throttle as a function that can be reused multiple times without having to copy-paste it. Right now with global scope creep this can be done indirectly, but it's a bad practice and also will depend on event execution order (event that defines function must be guaranteed to be launched first). It would be great to have separate script editor where i can define all global functions/variables.
UPD: after thinking for a while, it might be a bit more tricky to implement this function, as Throttle usually implemented via capturing state variable in closure, creating new function instance for each usage. Need to think more about how to best implement it in this plugin. Anyway, having set of global functions is still a good addition.
3) SUGGESTION: add enable/disable flag to each object to allow for quick temporary enable and disable of mapping
question: how data can be backed up / restored? if i recover LM from backup, how i can make sure that application configuration is restored as well?
Thanks for feedback.
As any other app the app is backed up with the device backup.
We will think about the throttle.
Why would you want to disable mapping?
Quote:Why would you want to disable mapping?
not all mapping, just certain ones for debugging or other purposes. Like you can disable individual event scripts.
Quote:We will think about the throttle.
Throttle is just one of the possible filter functions. But to be honest, i've checked my current mappings and this is the only stateful function that i'm using, so maybe build-in implementation will be sufficient. Still some kind of global functions might be useful in the future.
Having a local environment for each script is possible but this way certain functions might misbehave. This needs testing.
Reusable functions: a possible solution are user libraries so only one require call is needed in each script.
Configuration is placed in storage so it's a part of the backup as Daniel already mentioned.
Quote:Reusable functions: a possible solution are user libraries so only one require call is needed in each script.
good idea, i forgot i can use require() call, will try this appoach.
I'm currently doing exercise remapping all zigbee devices from my script to this new application, and i found few suggestions that i think will make it easier.
1) According to (industry) standard of zigbee2mqtt, device state should be set via same topic with "/set" suffix. So to control and read state of the device (for ex. relay), I cannot use "Both" direction, since value and control topics are different. I need to create 2 separate rules, one for IN and one for OUT.
- SUGGESTION: for "Both" setting, add separate optional SET topic to the configuration window
2) I think (from my case) 90% of zigbee devices are sending single usable value in a json property, the rest of the values are system info like link quality or battery info, which are usually not mapped. With current implementation it is not possible to extract this single value without writing several strings of code over and over again.
- SUGGESTION: add support for extracting attribute value directly. Potentially topic syntax can be extended to something like this: "zigbee2mqtt/sensor_name[@temperature]". You can even extend this to passing named variables to the script, like "temperature" becomes local variable in the script holding extracted value.
BUG: mappings list is not sorted, please implement sorting by topic name, then direction, then mapped object, so in/out events can be grouped and displayed correctly
UPD: i moved all my rules to the new application (54 total) Smile hope it won't break anything :-D
so regarding throttle, the following approach seems to be working, with the knowledge that i should use unique names per each script
"In" event:
ls_bedroom_throttle = ls_bedroom_throttle or require('user.mqttclient_common').throttle(60) local data = json.pdecode(payload) if type(data) == 'table' then   return ls_bedroom_throttle(data.illuminance) end
user library:
return {   throttle = function(timeout)     local last_update = 0     return function(val)       if(val ~= nil) then         local now = os.time()         if((now - last_update) < timeout) then           return nil         else           last_update = now           return val         end       end     end   end }
SUGGESTION:
1) in error log make it obvious which script contains error, so i can fix it easily. For example this error does not have information where to look:
Quote:error: failed to run script - [string "in-26"]:9: attempt to compare nil with number
2) output errors in global error log so they can be noticed in time
There is new version in the original post.
(27.09.2024, 08:13)Daniel Wrote: There is new version in the original post.
Thank you for listening and updating the app. Now the configuration has become much easier with new Json Path setting.
Have you though about improving "Both" 2-way config? I may be mistaken, but i haven't seen any scenario where In and Out topics are the same.
One more observation: there's a case when i have to copy&paste between many objects: relays. I think there're 2 main devices that produce binary value: contact sensor (it already produces true/false, no need for conversion) and relay which produce on/off.
When configuring Relay, i always need to add script "return value and 'on' or 'off'", and when converting the other way, usually parse from Json as well.
Suggestion: if target knx address is a 1 bit object, add drop-down with source value type: Boolean / OnOff, for automatic conversion. Same for Out, if Source is a 1-bit, add the same type of drop-down for target conversion. This way it will be possible to simplify configuration to only Json path and Object type, without need to write script.
The main use case for Both is to connect several remote LMs via MQTT and exchange objects values this way. If separate control and status topics are used then usually two separate objects for control and status are also used.
On/off conversion can be added but it should implemented as 2 user-editable fields to cover all possible values.
thanks for clarifying on Both, that makes sense now. Flexibility of the tool allows to implement the rest.
Hi, with MQTT client app is possible to send a MQTT payload like these?
{"ts":1451649600512, "values":{"key1":"value1", "key2":"value2"}}
A small script is needed for this. Where are the values coming from?
(02.10.2024, 08:18)admin Wrote: A small script is needed for this. Where are the values coming from?
timestamp from LM and value1 &  value2 are knx object.
Maybe only timestamp + one value is enough
For a single value use this script.
return json.encode({   ts = os.time() * 1000,   values = {     key1 = value   } })
For multiple values grp.getvalue() can be used but the you need a separate topic entry and script for all values in the same payload:
return json.encode({   ts = os.time() * 1000,   values = {     key1 = value,     key2 = grp.getvalue('0/0/3'),   } })
Can't use search in Mapped object field. does  it work?
Thanks for testing! Yes, search is broken in the current version. This will be fixed in the next release.
i'm trying to connect to a broker with port 8090 but doesn't work.... with MQTT Explorer and the script is fine
What do you have in the client app logs (click info icon)?
(02.10.2024, 13:00)admin Wrote: What do you have in the client app logs (click info icon)?
2024.10.02 15:04:41    connection started
and red LED in the corner
