18.09.2024, 15:28
LM Home app (Andrоid/iOS starter)
18.09.2024, 15:30
Did you update starter app to the latest version? We had to make workaround for it.
18.09.2024, 15:46
20.09.2024, 10:34
Hi, can you please provide .apk file again
? Will it work on Oreo 8.1 android (specific web display).
20.09.2024, 10:56
LM Home app works from Android 10, I can share the old LogicMachine app which should work on it.
Or you can just use a shortcut, with new authentication it also should work well.
20.09.2024, 11:33
Please provide old app, will try to use it
Alex
28.09.2024, 03:26
(This post was last modified: 28.09.2024, 03:27 by Hoang Hien.)
This function is awesome, when will this feature be completed on IOS
28.09.2024, 06:58
Jus search for LM Home on the app store
29.09.2024, 08:25
02.10.2024, 07:25
I'm having trouble finding my LM after I have switched to a new phone.
I downloaded the new app from the play store version 1.0.240709 but it cannot find my LM, but if I go to the LM's local IP (192.168.1.20) I can see it and login.
02.10.2024, 07:29
(02.10.2024, 07:25)Novodk Wrote: I'm having trouble finding my LM after I have switched to a new phone. You must have 2024 fw for it to work
02.10.2024, 07:31
(02.10.2024, 07:29)Daniel Wrote:(02.10.2024, 07:25)Novodk Wrote: I'm having trouble finding my LM after I have switched to a new phone. I have
02.10.2024, 07:38
02.10.2024, 07:43
Strange, I also have Android 14 and it finds all my LMs. When you say: you can login to LM you actually do it from your mobile?
What do you see when you open the app?
02.10.2024, 07:51
(02.10.2024, 07:43)Daniel Wrote: Strange, I also have Android 14 and it finds all my LMs. When you say: you can login to LM you actually do it from your mobile? Yeah, my LM have 192.168.1.20 if I go to http://192.168.1.20 on my phone that is connected to my wifi on the same network I get to the standard LM login page, and I can login and use all the features. When I open the app it says down the bottom: "Searching for LogicMachine devices" when it's done searching it says: "No LogicMachine devices found" "Try again"
02.10.2024, 08:16
Try running Wireshark on PC connected to the same network. Set filter to mdns then run LM Home on your phone. See if you get MDNS query from your phone and a response from LM.
Should be similar to this: (02.10.2024, 08:28)Daniel Wrote: Is this the only LM on your network? yes (02.10.2024, 07:51)Novodk Wrote:(02.10.2024, 07:43)Daniel Wrote: Strange, I also have Android 14 and it finds all my LMs. When you say: you can login to LM you actually do it from your mobile? Is this enough?
